Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Cant get decent speeds from u torrent
My U torrent screen has a warning icon in orange saying "no incomming connections, unless icon turns green it could indicate a problem with the network configuration". I have also run a test on my port which is apparently not forwarded properly.
Help please!
  • mackygee Apr 28, 2008
    my problem is exactly the same
  • Kathy Mitchell May 11, 2010
    I also have the same problem. I have a Netgear DG834 modem/router hooked with a Belkin F5D7230-4 as the wireless router for a laptop and another computer in the house. I have rang Belkin but they are no help. If you need any further info please let me know.
Portforward.com
Posted on Mar 08, 2008
  • 38 Answers
I can help 100% with this.
You need to set up port forwarding.
if you give me your router make and model I will give you step by step instructions,
Regards
Tony
Posted on Feb 28, 2008
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Won't turn on unless plugged in
Either the battery is faulty or a wire is no longer connected properly. I would get the repairers to check their work.
Apr 28, 2014 | Samsung Chromebook Series 3 XE303C12
All of a sudden I can't torrent, error message says no incoming connections?
Check to make sure that your internet is connected and working properly.
May 19, 2012 | Edimax BR-6226n nLite Wireless Broadband...
Need to hook up a hopkins converter trailer light system up to 2008 jeep compass; Dont't have the wiring harness system. I have four wires to connects: Brake. trun RT, turn LF, tail, and ground I...
The Left Turn signal is DARK GREEN/RED
The Right Turn signal is WHITE/YELLOW
The Left Brake light is WHITE/ORANGE
The Right Brake is WHITE/RED
The High-Mount Brake lamp is DARK GREEN/WHITE
Now, with all that said, your Jeep should be already equipped with trailer wiring unless you have the cheapest model of Jeep Liberty available. I would check your Owner's Manual on the subject.
Also, your rear lighting is controlled by the Body Control Module (BCM) and the signal and brake inputs/outputs are all transmitted to the Instrument Cluster Module for your lamp-out warning system. Anything you connect to this wiring can adversely affect BCM function or can cause your lamp out warning to malfunction and come on all the time. I would use extreme caution unless you really want to destroy some HIGH DOLLAR electronics in your vehicle.
Sep 11, 2011 | Jeep Compass Cars & Trucks
Got utorrent and down loaded ipv6 ,download speed very very slow disabled ipv6 and uninstalled utorrent and re installed utorrent and tryed other torrent downloaders all say ipv6 installed ,done the...
With utorrent you have to go into the options menu at the top right, then click preferences....once in there click on 'Connection'. The information window to the right has some changes you need to make....the first one where it says 'Port used for incoming connections'...change that to 64450 (you can use any random number over a certain range I generally choose one between 62000-64999). Now right below that, make sure the check box 'Add Windows Firewall exception' is checked. Now click 'Ok' and close the program then go and try to download your torrent.
(If you are using a 3rd party firewall program you will need to go in and enter an exception for utorrent manually)
Feb 23, 2011 | Computers & Internet
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
My college has blocked the torrent downloading i can only able to download the .torrent file but i cant get the speed that is the nodes didnot login bin my utorrent client i have used ultrasurf for the...
You cannot get the speed because they closed the port used by torrent on the main router.
Unfortunately there is nothing to do about this , unless you have direct access to router configuration.
Feb 26, 2009 | 2008 Pontiac Torrent
Utorrent
yes that indicates that there are no incoming connections..when u click on the triangle you come to an option that says to check if port is forwarded properly and to configure the connection speeds..
i am a regular u torrent user and my port is never forwarded correctly..despite the orange triangle i get very good download speeds..a trick i use is to use the"force start" option on the downloads..right click on a downloading torrent and use force start option..i also noticed that over time the triangle becomes green..hope it helps!
Oct 31, 2008 | Enterasys Distributed Forwarding Engine...
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Port mapping
check that you have the rellevant port open and also at certain times of the day it depends on how many are online and the seeds connection speed.
see here for instructions on port forwarding
Oct 23, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
43 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
