Question about Amana AFD2535DES French Door Refrigerator
Intermittent fault Hope you can help, freezer sometimes freezes and sometimes does not, water dispenser has the same problem, fridge also does the same but not as much, can you please let me know what you think and if i need to buy parts what the part nos. are. thank you, my email is apmpainter@hotmail.com Dave.
  • Scozzy Feb 26, 2008
    aborcass thanks for your reply, yes my freezer stops and restarts without me touching anything, i notice this because the ice in the ice bucket starts to melt and drips into the water dispenser tray, also the ice bricks that you use in an esky they all melt, these turn to liquid then the next time you check it out they are frozen again and it has started making ice again.
  • Ron Coons
    Ron Coons May 11, 2010
    your freezer stops??? you notice this how???is ice cream melting, meat defrosting???and what just starts up again w/o you touching anything?
    President:
  • Amana Master
  • 2,651 Answers
I would check for compressor issue, listen for noises clicking, on/off.you can pull refrig out and remove back cover, is the compressor(football sized motor) red hot? when unit not runnig (shoud be warm not red hot)
Posted on Feb 27, 2008
Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Oct 09, 2009 | Refrigerators
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water dispenser line keeps freezing
no idea.probably need to contact the technician of the manufacturer's firm.
Apr 10, 2009 | Kenmore Refrigerators
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Have a samsung American style fridge/freezer with water and ice dispenser. Water gets to the water dispenser but not to the ice cube maker. can not see anyway of getting to the pipe inside the...
verify on the back side of fridge sometimes you will see the water lines if not there's like a a cover that goes vertically if removed, probably you'll have access to water line its probably plugged up...
or sometimes air gets trapped in the supply line to purge just simply loosen the nut or fitting it should spit some water do this just enough to let air out about after 30 sec. if there was some air in the water line i should start to spit water...
hope i could be of help
Apr 13, 2008 | Refrigerators
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
Water Dispenser Freezing Up
I would suggest that you turn the fridge temp up so that you are not cooling the fridge too much. However I suspect that you have a problem with your freezer section and the airflow is going in at the bottom of the fridge and not feeding in from the top. If you are competent I would suggest removing the back panel (lower internal) on the freezer section and checking that the evaporator coil (finned aluminium) is clear of ice. If you see an ice formation then you probably have a defrost heater out. If you defrost the unit then it will temporarily sort out the problem but I would suggest getting a fridge guy if your wife is getting mad already.
Hope this is of some if limited help.
Mar 13, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Amana AFD2535DES French Door Refrigerator Logo
52 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
