Question about Gateway FPD2275W LCD Monitor
My computer screen is not straight
The whole screen is not staight and the bottom right corner is curved in so it is black in the corner
also the top part of the screen can not be viewed
  • Anonymous May 04, 2008
    the bottom left of my screen is curved when i try to fix it the top lft disappears
  • 151 Answers
You can set screen by frontpanel keybord of monitor.if They not work then change these button on circuit board.if it not work till then check command ic.
Posted on Mar 01, 2008
How to fix Samsung 58 TV display got half black curved line?
Hi Mazy, sorry to hear about this...
Problem with plasma screens is that they do have a limited life, they also do not like to travel. You have to keep them upright because the glass panel is so heavy. Did you lie it flat for transportation? Is the black area in the middle bottom or in the corner? If it is in the corner, and the mounting point has a problem, it could cause this, but hard to say without seeing it. Does the black area retreat when it is off and cools down? I doubt if it is the system board, sadly if it is the display panel, it would not be worth fixing.
Let me know if you have more details... Good luck.
Nov 14, 2014 | Televison & Video
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Dirty lense, out-of-line projector?
in the power supply there are a couple of fuses they are either green or yellow they look like resisters check them with your meter one of them is going to be open replace both.
Mar 04, 2010 | Sony KP-57WS500 57" Rear Projection...
Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Sep 18, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Black corner on laptop screen and burnt smell
The problem you have is caused by a defective LCD inverter.
They really really fragile and the job of replacing them can be quite tedious.
There is not other reason for your screen corner to became dark.
Send it back and tell them that the replaced part is defective or it was not properly installed.
I hope this help you out.
Aug 10, 2009 | Dell Inspiron 8000 (6158u) Modem
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Vertical pinch on left hand side of crt
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Jan 22, 2009 | NEC MultiSync XV17 17" CRT Monitor
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Gateway FPD2275W LCD Monitor Logo
67 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
