Question about Creative Labs ZEN Vision:M Digital Media Player
My Zen wont turn on.. Help!!
Hi ... My Zen Vision M dont turn on when i use the power button.. but when i hook it up to the ac adapter it work.. how to i solve this problem ? Thanks in advance.
I had that problem, I took it apart and fiddled the cables a little, now it works perfectly. http://www.anythingbutipod.com/archives/2006/02/how-to-disassemble-the-creative-zen-vision-m.php
Posted on Mar 05, 2008
Go fuck it :D
Posted on Mar 04, 2008
I am having the same problem and i can only see it when i am kinda in the dark and i cant make out any of the pictures of videos on my mp3 player help me please
Posted on Mar 01, 2008
Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Aug 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
My zen won't turn on. only the blue light flashes when its plugged in. the screen doesnt turn on. what does this mean thanks
Well you can try this if you still got the zen, press the reste button, dont hold just press it then hold down the power button and it will start up but mine just kept on going black fter a while so i had to put it into recovery mode by doing the following.
Hold down play untill the end
Press the reset button
Hold down the power button
Makes sure you releas the play button last
after that do Reload Firmware i think
then it will delete the firmware make sure you have this downloaded on your computer
http://support.creative.com/downloads/download.aspx?nDownloadId=10889
its the newest firmware
when you downloaded this plug in your zen into the computer and it should turn on your zen and then say Firmware problem and if it doesnt just put it into recovery mode then plug it in.
Then make sure all application are turned off like Mozzila or the Internet Explorer, then just double click on the firmware and it should fix
Feb 01, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Trouble
167labrie does your zen power up while it is plugged into the ac adapter? If this is the case it is a bad battery. I had this problem where the unit wouldn't take or hold a charge from the ac adapter or the usb cable and they ended up replacing the unit.
Dec 29, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative not charging
there seems to be a problem with the batteries for the Zen. I have just sent mine in for warranty work as it will work if you have it plugged into an AC adapter but it won't work as soon as it's unplugged even after charging all night. The USB will not charge it either. Creative has sent a replacement unit, but there is a serious problem with the battery.
Dec 24, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
read this:
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Doesn't turn on
If charging by USB is not charging your player enough to even be able to power up, then you're going to have to get hold of an AC wall charger that plugs into the ZVM's round DC-IN jack (on the sync adapter). PSP chargers work perfectly, if you have one. Let it charge for a few hours this way, then post back.
Dec 07, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
