Question about Kenmore 22422 Top Load Washer
Water won't fill up all the way up on large cycle, I must manually fill to desired level then shut off
  • MSRACHEL May 17, 2008
    I have the same problem. Do I tilt it to take it out? Or tilt it just to tilt it?
  • 1,314 Answers
Change your pressure switch its the one where you select your water fill level back out the two screws on each side of the control panel back or front pull it slightly forward then tilt it back should be a gold dome with a plastic hose and three wires
Posted on Feb 26, 2008
My ge top load washer will not stop filling up with water
The water level switch shuts the water off when it gets to the desired amount. Also change the water level to low and see if it stops at different level.
Jan 06, 2015 | GE Washing Machines
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Jan 12, 2013 | Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity...
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
It does fill to capacity on the rinse cycle only on large or super levels.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 06, 2011 | GE WBSR3140DW Top Load Washer
My washing machine wont stop filling up with
well the part that tells the water to stop running in is the pressure switch if the water valve is working properly so disconnect the power and if the water continues to run in it is the water valve just replace it
Apr 26, 2010 | Washing Machines
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Every cycle has its own water measurements for example: Heavy Wash : 7.2 gal. so check the manual for further information. And don?t worry there is an Overfill Protector, so you won?t do any damage. Good luck
Apr 01, 2006 | Frigidaire 25 in. FDP750RC Free-standing...
Kenmore 22422 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
