Question about IBM ThinkPad T30 2366 Notebook
Stopping at the BIOS Splash screen
I just had the no power problem with my T30 and replaced the keyboard. It now powers up , but stops at the screen that says "IBM Thinkpad". I am able to press F1 at anytime and go to setup, but it won't boot any devices and when I press F12 to choose temporary boot sequence it freezes up.
  • pete3275 Mar 08, 2008
    IBM think pad won't show the display. Screen went dark and started making a beeping sound. Not sure what to do here. Is there a way to reset or run an alternate program.
    I don't know how to fix this problem.
  • Justin McFarland
    Justin McFarland Feb 02, 2009
    I eventually fixed my problem, I simply replaced the Hard drive and it worked.
    Scholar:
  • 80 Answers
Hi
Reseat all the RAM, CMOS battery and any PCI graphics cards and then try to boot the computer.
Also remove all the memory cards and then turn on the computer. If you dont get any beep sounds, then it is a problem with 1 or more RAM cards.
Then alternatively try with 1 RAM at a time in different slots and check if it is a problem with any of the RAM cards or the RAM slots.
Posted on Feb 26, 2008
Why does my P6211f fail to boot? It runs and stops, runs and stops. No logo. Black screen.
If you dont see the bios splash screen, then it is the power supply or BIOS. in either case, you will need to take it tocthe repair depot.
May 16, 2014 | HP Pavilion Computers & Internet
Asus r503u bios
Shut down your Asus laptop. Click "Start" then click the "Shut down" button. Power your computer back on. Wait for the ASUS splash screen. Press the "ALT" and "F2" keys on your keyboard as soon as you see the ASUS splash screen. Your computer will enter the BIOS.
Feb 14, 2013 | ASUS R503U-RH21, AMD E2-1800, Laptop, 4GB,...
Clearing the bios password
When you first turn your computer on, you are briefly presented with a BIOS "splash" screen. Somewhere on this screen (just where depends on the manufacturer), are instructions on how to access BIOS settings. Generally, this requires tapping a function key, say F2, while the splash screen is visible. Make note of which key the splash screen says to press to access the BIOS and restart your computer.
When the computer boots and the splash screen appears, tap the required function key quickly to enter the BIOS settings screen. You will only have a couple of seconds to hit the right key and if you miss it you'll have to restart the computer and try it again.
Once you successfully enter the BIOS settings screen, use the arrow and function keys to navigate the menus. Keep an eye out for an option that says something akin to "reset to factory defaults." If you see this, follow the on-screen instructions to reset the BIOS to the factory settings. Then, confirm your choice and exit the BIOS screen, usually by pressing escape. Congratulations, you are done.
If your BIOS does not have an option to return to factory settings, things are more difficult. Because the BIOS is stored in ROM, it must have a constant power supply to store any changes you make to it, otherwise it would reset every time you disconnected your laptop from AC power. Removing power to the BIOS resets it to factory settings and involves disconnecting a small battery attached to the motherboard. On many laptops, the BIOS battery is easily accessible through a door on the bottom of the unit. Unplug the computer, remove the main battery and touch something metal to ground yourself.
Remove any screws holding the BIOS battery door in place. Then identify the battery, (it is generally a small lithium "watch" battery), and remove it taking care not to damage any surrounding circuitry. Let the computer rest for a minute or two to discharge any remaining power, and replace the battery.
If your laptop does not have an easily accessible door for the BIOS battery, you may have to dive deeper and disassemble the computer to find it. Consult your laptop manufacturer's website for information on replacing or removing the BIOS battery from your model.
  • 2 When the computer boots and the splash screen appears, tap the required function key quickly to enter the BIOS settings screen. You will only have a couple of seconds to hit the right key and if you miss it you'll have to restart the computer and try it again.
  • 3 Once you successfully enter the BIOS settings screen, use the arrow and function keys to navigate the menus. Keep an eye out for an option that says something akin to "reset to factory defaults." If you see this, follow the on-screen instructions to reset the BIOS to the factory settings. Then, confirm your choice and exit the BIOS screen, usually by pressing escape. Congratulations, you are done.
  • 4 If your BIOS does not have an option to return to factory settings, things are more difficult. Because the BIOS is stored in ROM, it must have a constant power supply to store any changes you make to it, otherwise it would reset every time you disconnected your laptop from AC power. Removing power to the BIOS resets it to factory settings and involves disconnecting a small battery attached to the motherboard. On many laptops, the BIOS battery is easily accessible through a door on the bottom of the unit. Unplug the computer, remove the main battery and touch something metal to ground yourself.
  • 5 Remove any screws holding the BIOS battery door in place. Then identify the battery, (it is generally a small lithium "watch" battery), and remove it taking care not to damage any surrounding circuitry. Let the computer rest for a minute or two to discharge any remaining power, and replace the battery.
  • 6 If your laptop does not have an easily accessible door for the BIOS battery, you may have to dive deeper and disassemble the computer to find it. Consult your laptop manufacturer's website for information on replacing or removing the BIOS battery from your model.
  • Read more: How to Reset the BIOS on a Laptop ' eHow.com http://www.ehow.com/how_4740583_reset-bios-laptop.html#ixzz1YX2FMmVc
    Sep 20, 2011 | HP Pavilion ze5375us Notebook
    How to reset bois for a MSI laptop model # ms-no11
    5
    6
    Thanks.
    Have a great day.
    Oct 12, 2010 | Computers & Internet
    My Computer won't but up- the fan goes, the lights blink on the keyboard but then the hard drive quits spinning. I suspect I have a virus. Can I do anything to fix this? I have a Norton Antivrus program...
    You should see the HP logo splash regardless of any virus or what the Hard Drive is doing. Abscence of the splash screen at boot means something more essential, such as the power supply or a motherboard or processor is amiss. You may want to substitute another working power supply. Also inspect the large standup capacitors on the motherboard for swelled tops. If you see swelling then the caps have failed. Most people will look for a replacement motherboard when that happens, though the capacitors can be replaced. Replacement requires a 100 watt regulated soldering iron and good soldering skills, the capacitors themselves are not expensive.
    If you are seeing the HP splash at boot, then your bios settings may have gotten corrupted (which you can set to the defaults to clear), or the Hard Drive may have a failure. To default the bios, hold the "delete" key at boot to enter the bios setup page. If you can enter the bios, load the defaults (typically F7) save and exit The system will reboot, and perhaps come back to life.
    Nov 22, 2009 | HP Media Center M370N (DM163A#ABA) PC...
    System wont boot
    Disconnect all devices except keyboard and mouse and master cd or DVD. unplug then hit power button. Plug back in. Hit power and hopefully you get to BIOS. If you do make sure you save the BIOS before you leave to start OS. Keep me informed and I'll keep checking your listing to see if its working or not.
    Sep 24, 2009 | Computers & Internet
    BIOS password for IBM T30 Laptop
    please you need to reset its bios. open the screws behind your laptop with keyboard icons to access your laptop cimos battery with care remove it for some time(3min), power on your laptop until it boots up. turn it off and put the battery back. the password will removed.
    Jul 24, 2009 | IBM ThinkPad T30 2366 Notebook
    IBM T30 screen ramdomly goes blank and computer freezes.
    Reset your bios settings to "Bios defaults", then disable power management.
    In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
    Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
    T30 Power up problem
    The c-mos won't cause this. The power button is integrated into the keyboard, and uses the same connector as the keyboard to get power to the system. In most cases, the board with the power button (which is part of the keyboard) is worn out. Occassionally the keyboard connector will work loose or get a little corrosion or dirt and not make a good contact, check and clean the connection. If the connection is good, then I'm afraid you will need to replace the keyboard in order to cure the problem.
    Jul 15, 2008 | IBM ThinkPad T30 2366 Notebook
    Asus m2n-e sli locks up at bios post splash screen
    Sounds like a bios issue. Try resetting the bios, pg. 2-19 in user manual. After clearing the bios jumper, make sure you set it back to pins 1 & 2. If you still can not get into the bios main menu than head to Asus, click this link.
    http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
    Since this is a new board & all Asus boards are warranted for three years I suggest you talk with an Asus tech. If you flash you're bios during the warranty period you may void the warranty. You can call Asus M-F, EST 8:00AM-5: PM.
    1-812-282-2787. Not sure you have this number in you're manual. Chances are Asus will send you a new bios. Or you can buy a new bios for $5.00 not including S/H. From Asus online store. Click on this link. http://estore.asus.com/shop/
    If I can be of more service, just post back & let me know how thing go.
    Mike
    Apr 27, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
    IBM ThinkPad T30 2366 Notebook Logo
    175 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
