To setup your Wii Controllers. Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries.
Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu.
Open the front door on the front of the console to reveal the SD card input and the "Sync" button.
Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash.
Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect.
Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on.
Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
SOURCE: HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
SOURCE: wii remotes lost connection with console
You need to open the small compartment on the front (located between reset and eject) were your can insert a sd card. Above the slot will be a red button labled sync. Press(maybee hold) the button and press the 1 and 2 buttons on the remote. This should get your remote working with your wii.
----John
SOURCE: Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
SOURCE: Can't connect my Wii remote to the Wii
Take off the battery cover on the back of the wii remote and open the slot on the front of the wii where you put in the memory card:
http://g-ecx.images-amazon.com/images/G/01/ciu/09/d4/42196230a8a096736e5af010.L.jpg
Press the red button by where the batteries go in the remote and the red button by the memory card slot together and they should find each other and synchronise properly. If they ever lose synchronisation again just repeat the process.
SOURCE: wii remote won't connect to the wii console
Here is what I went through, hopefully it will save you some time.
The first thing I did while the Wii was turned on was that I tried to sync the Wii Remote by pressing the "1" + "2" buttons at the same time. The lights at the bottom of the controller flashed for about 30 seconds, but never received the signal from the Wii. Bummer.
The next step I followed was to hit the sync button on the Wii Remote (Wiimote). Then immediately opened the cover for the opening where the SD Flash card goes and pressed the sync button on the Wii. 30 seconds of flashing, and no result. Double bummer.
Finally, after some Google searching, I found a couple of message boards where people had to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. I performed this step and then pressed sync on the Wii Remote. The 2nd controller synced up almost immediately. What a relief!
Apparently the problem lies in the fact that the Bluetooth technology being used has to be manually synced in order for it to connect to the Wii. It does not make much sense at all. You would think they could be pre-authorized in order to minimize time and ease of use. In addition, you really have to be careful that your other controllers are turned on while syncing or else the controller that you are trying to put on channel 3 might end up on channel 2! This happened to me on one occasion.
Good luck with getting your Wiimotes in sync with your Wii. Hopefully this helped!
