Question about Mitsubishi WS-55807 TV
Lose Picture After the TV has been on for awhile the picture will suddenly go black. Just as it is going black, there is a swirl of color in the center of the screen. If I turn off the power and wait about 10 minutes, the picture returns like normal. There is no flashing of the green power light.
    Scholar:
  • 135 Answers
Hi there!
May be power supply related (old capacitors),dry joints on the main board or dry joints in the video amp section. Check for loose or bad connections. Good luck,JUS004
Posted on Feb 29, 2008
Colors are not as per actual
Missing a color or a swirl of colors? it could be a Degaussing problem, you should hear a clunk when the set first comes on cold.
If colors also do not look right turn color all the way down and look at screen, do you have a good black and white picture?
Dec 02, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dvd is connected and picture is black and white
red, green and blue should go to Component not composite.
Mar 13, 2012 | Coby LEDTV1926 19 in. TV
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
I woke up to find the that the picture looks like a blob of changing colors. the sound works find for the picture looks like just water colors swirling around
HGi, Unplug TV for 30minutes and then see what happens. If it clears up you are good to go. If it does not. Have a repairman look at it. Also check all connections for proper connect. Good luck.
Jun 15, 2011 | Insignia NS-P502Q-10A 50 in. HD-Ready...
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
I have an LG 42" plasma tv (model: 42pc1da) and I am having a major picture problem with it. Last night, while watching the television, I heard an audible "pop" and the picture started to dim. I turned the...
The sound you heard came from one of the IC's under the heat sinks. Check the fuses on the left and right print, the print with the broken fuse must be replaced.
Sep 03, 2010 | Televison & Video
Picture color issue
the tv need to be open because ,their's a lose connection of the CRT section and it needs to resoldered
Jan 26, 2009 | RCA 20F424T 20" TV
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
