Question about HP LaserJet 3055 All-In-One Printer
HP LaserJet 3005 wont install on HP laptop
I have a client who has an HP printer on the network, 5 people can print fine and 3 can't. When I use the install disc it goes all the way to the finish but right at the end it says cant finish install an error occured!!!
Could it be conflicting with the HP Director and Photo Viewer????
  • Zen103 Feb 26, 2008
    Yes, they all have the same permissions!!! There is 7 people that work for the company, 3 of them are part of the network and the 4 others just access the network wirelessly. The printer is on the network and not shared through a PC.
  • Louie67 May 13, 2008
    When I installed my hp 3055 at work it somehow did a number on my hp 7310, now I can't scan anything. when I click on HP Director it says it has encounter a problem and it needs to close. I'm also getting a RPC server is unavailable. I already deleted the drivers and installed them again a couple of times and it doesn't work!
Reqward software drivers for hp 3055 all in one my e-mail id praffulcarcare@yahoo.co.in
Posted on May 15, 2008
    Genius:
  • 3,587 Answers
HP director? the admin utility. most likely yes...Photo viewer, most likely NOT...are the 3 that can't set up differently(permissions) than the other five?
Posted on Feb 26, 2008
  • Patrick Michaels
    Patrick Michaels Feb 26, 2008
    do those three have HP Director installed?
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | HP LaserJet 1020 Printer
My Xp clients are on windows server 2003 domain. My clients are using HP LaserJet 1020 printer which is shared on network. My users complaints that when they print any documents, Printer does print fine...
http://support.microsoft.com/kb/314073 hope this will help you or else please give me remote session of your computer
Available at Skype:- amit.bhardwaj4
Mar 01, 2010 | HP LaserJet 1020 Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Need teflon for HP laserjet 3005
www.hp.com seems to be the place to start looking for OEM parts
Jun 12, 2009 | HP LaserJet P3005n Printer
Cant connect (or see) my LaserJet 5000 on Windows XP
In XP go to START > CONTROL PANEL > NETWORK CONNECTIONS > LOCAL AREA CONNECTION
you should see a menu showing your network card and a window that says stuff like Client for Microsoft Windows. Below that window is an INSTALL button. Click on that and double click PROTOCOL. Select IPX/SPX NetBios and hit OK. You'll probably need the WindowsXP CD to finish installing the protocol.
The LJ5000 is a very old printer and if I remember correctly, it uses the IPX/SPX Netbios language to communicate through a network. Netbios is not installed by default in XP.
May 08, 2009 | HP LaserJet 5000 Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Printer installation
Jim,
This can be done as a network device, AFTER it's installed as a local printer. I know, it's nuts, but we're talking MSoft.
drivers for printer are unique to a PC, so make sure you have the best ones.
Jul 19, 2008 | HP LaserJet 3030 All-In-One Printer
Hp 3005dn wont start up all the way
The unit has a bad formatter. The formatter generally comes with memory installed Part# Q7848-31004. Part is super easy to change 6 phillips head screws and 3 cables (ribbon, 6 pin, and 3 or 4 pin power) Remove formatter cover the remove formatter door by opening then lifting up, then unplug the 3 cables then remove the 6 screws. Install is reverse of removal.
Jun 18, 2008 | HP LaserJet P3005n Printer
Driver Installation
hi friend
u have to do this
1.plge in ur usb printer cable on usb port
2.do not on ur printer
3 put ur printer cd in ur cd rom drive
4install ur printer software
5 in between the installtion ask to u power on ur printer then u have to on ur printer
5 completing the printer installtion
try to print
& thnx uing fixya
Apr 01, 2008 | HP LaserJet 9040n Printer
Unable to connect to printer
actually it may be a network problem. I have had 10-15 machines go down and lose the printers at the same time in a hospital and the sloution was to turn them all  off and on to reset it. Sometimes it would happen 3-4 times a month. A glitch in the network.
Assuming these are all network printers.
Oct 04, 2007 | HP LaserJet 1022 Printer
HP LaserJet 3055 All-In-One Printer Logo
445 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
