Question about Haier HSB03 Compact Refrigerator
My refrigerator makes a loud noise whenever it is maybe switchin cycles? I'm not sure. Almost like one of the bolts that ties the compressor 2 the frame is not on there or something. It freezes on an off also. Could the 2 problems have anything 2 do with 1 another?
  • tjv2634 Oct 30, 2008
    The fridge makes a real loud noise when what I would think it is doing is kicking on the cooling unit. It is a real loud humming noise that keeps me up at night, and I don't know what to do about it.
  • hyandrasits Dec 09, 2008
    same thing it sucks how do i fix it
My daughter`s fridge in dormotory is not cooling , where is the nearest repair center to SUNY Geneseo campus
Posted on Apr 01, 2008
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Apr 02, 2015 | Refrigerators
The compressor is making a loud noise
If you are sure the noise is coming from the compressor.You need to call a tech. to check the unit out.
Jan 31, 2012 | True Deli-Cases TSID-72-4-L Refrigerator
There is a loud vibration noise whenever the compressor is running. Everything, including the coils on the back of the box vibrates so loudly that it can be heard in the next room. The compressor appears...
Is the evaporator coils froze up? Sounds like maybe the compressor is getting liquid back to the compressor or the compressor is running real high head pressure. Also check and see if the compressor is mounted on springs or pads.. Make sure all of the refrigeration lines are not bent and causeing vibriation.
Dec 19, 2010 | Kenmore Refrigerators
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Loud noise from GE Side by Side
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 07, 2009 | GE GSS22JF Side by Side Refrigerator
When our refrigerator kicks on, after a minute or two it makes this loud whining, from soft to loud, that lasts about 2 to 3 seconds and does it continually till it kicks off. It's like, Waaaaah, waaaaah,...
This sounds like a compressor that is whining. Or something maybe wrong with the fan motor. You can stop the fan to see if its still there. If it is then its the compressor making the noise.
Sep 13, 2009 | Haier Refrigerators
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Excessive noise when refridgerator shuts off
Remove the rear cover at the compressor and check for loose mounting bolts on the compressor and fan motor.
Feb 21, 2009 | KitchenAid Refrigerators
Refridge makes a loud noise
are you sure it is the compressor making the noise and what sort of noise is it. if it is the compressor, there is no cure except replacement which is not diy.
Mar 27, 2007 | Hotpoint HTR16ABSR Top Freezer...
Haier HSB03 Compact Refrigerator Logo
468 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
