Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
P2002 Amp is weak
I recently upgraded my system and gave away my old p2002 RF amp and 10" alpine subs to my neighbor. They worked great in my car. In his it is hardly getting any power to the 10" subs at all. The subs are good (I just pulled them out of my car) but sound is extremely weak in his car. Only thing I can think of is either his head unit has issues or the rca's are bad. I checked and ground and power supplies are good. Would appreciate any help. As I said system was in my car (1 week ago) and sounded great.
  • 300 Answers
Please provide details on the head unit, sub box, and sub box location of both your old setup and your neighbor's new setup.
Posted on Mar 05, 2008
I have a alpine CDE 152 head unit in my car and just put in alpine SPR 60 coaxial speakers in the rear. thought the head unit would be enough and want more punch from the base.. do i need an amp or i
get the alpine ktp445 mini amp ,it should be compatible (check your manual for your HU it will say ) its a plug and play install and you will hear a great improvement as I did and still got mine with the alpine cda 117 .
Apr 04, 2014 | Alpine Car Audio & Video
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
Hello i just recently bought alpine speakers for my eclipse 2003
mostly because the subs in the back are probley using more amps than the ones in the front in the front should be used mostly for vocals and your bass in the trun so maybe trying to unhook the ones in the front from the sub and just leave then hooked up to the cd player where you can hear the vocals really good and leave your subs in the back hooked up to the amp
Jul 27, 2009 | Alpine SWS-1223D Car Speaker
System Cuts Off
your amp is tripping out because the subs a drawing to much power get a better amp alpine subs demand a lot of power try a high current amp
Jun 30, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Weak output from sub..
The woofer was not demagnetized.
If one signal cable is damaged, it could reduce the signal getting to the amplifier and could reduce the output.
Plug one RCA plug in at a time to confirm that both are working properly. If one is lower or not working, the cable may be defective.
If both work properly, double-check the settings on the head unit (sub-out, bass, crossover frequency...)
Oct 28, 2007 | Alpine MRP-M350 Car Audio Amplifier
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
89 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
