Question about Evenflo Discovery - Midland Blue
Re-assembly instructions for evenflo triump car seat
I need to align straps and re-assemble car seat
where do the elastic straps for the cloth cover go back on?
  • kickboxnurse Apr 27, 2009
    My baby has grown and I have adjusted the straps at the biggest possible... need to move them one slot up but dont know how... please help!!!!
Been so long since I posted this, that I thought it was an imposter!
can't even remember my problem......
Posted on Aug 15, 2008
  • 88 Answers
Need directions on how to put together the straps on an evenflo carseat
First, read the instruction manual. If you need help (in the USA), go to and find a fitting station. They will help you.
Please DO NOT GUESS! The harness MUST be assembled correctly!
You can also contact Evenflo at:
Aug 07, 2014 | Baby Gear
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
Reattach seat to Evenflo Exersaucer
Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
Feb 07, 2010 | Evenflo Baby Gear
How do I attach the fabric seat of my evenflow supersaucer? It was detached for washing and now I cannot figure out how to re-attach it. Fran. I have the same problem the...
The seat back should be screwed securely to the other half of the plastic seat ring. Position cloth seat over seat back, lining up red diamond on cloth seat with inverted 'V' notch on lower edge of the seat back. The plastic tab and elastic straps go around outside of seatback and back through the narrow space between the two parts of the plastic seat. The elastic loop then hooks around the tab on the underside of the plastic seat ring.
Mar 30, 2009 | Evenflo Exersaucer Triple Fun Active...
Evenflo discovery 5 infant car seat straps
Okay okay--do not do anything with the big pieces behind the babies back but the gold clips at the **** area..pop those out and shove that piece and the clip and the chest clip through the back of the strap hole--then reput the strap through the slot you wish then the gold pieces back through the bottom and of course pop the gold pieces back--again do not use the upper clips behind the back to do this :0)
Sep 13, 2008 | Evenflo Discovery
Nope still couldn't get it following the instructions....Finally figured it out. start with the 3 plastic rings fully assembled on the saucer. Then you need to pull the fabric over the top of the upper plastic ring and then feed the elastic through between the upper ring and the middle ring from the outside to the center through the 1/4 inch space and then attach the elastic bands to the hook point. The fabric needs to be surrounding the upper plastic ring such that your child will not rest against the plastic directly with their head. the plastic tabs are really only for reinforcement, even though they fit perfectly and snap right in the the middle ring (took me a while to get over that).
Aug 17, 2008 | Evenflo Jenny Lind Crib
Old evenflo exersaucer
Jun 03, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Need help Question: How do I care and clean for my PortAbout 3/PortAbout V infant car seat? Answer: To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
Feb 23, 2007 | Evenflo PortAbout 5 Infant
Evenflo Discovery - Midland Blue Logo
807 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
