Question about D-Link GamerLounge DGL-4300 Router (DGL4300)
No connectivity to internet
Modem is working fine, router lights are all on but when router is connected cannot access internet on any computer. Have reset modem and router, rebooted, no luck
  • joe55 Feb 29, 2008
    appreciate the help but it turned out to be a faulty wire connecting the router to the modem.....Once it was replaced, everything worked fine....I do appreciate however the time and effort that was put into the response. You "techies" amaze me and I respect your brainpower
  • 51 Answers
Looks like when you reset the router/mdm you have los all yur configuration and back to the default factory settings.
Bridge the modem first .
1. In your web browser browse to »<your mdoms deault gateway> This address will be found in your manual of your modem
2,Depending on your modem make sure you use "Bridged Mode (PPPoE is not used)"
3. Click Save Changes.
4. Then connect the router
5.Configure the router for PPPoE using your ISP uid/pass
6.Configure your wireless using WEP(if applicable)
7.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Posted on Feb 26, 2008
I cannot connect to internet
What is the model number of your router?
Bypass the router and connect the computer directly to the modem.
Make sure that your computer is able to access the Internet through the modem.
If the modem is working fine the connect the modem to the router and computer to the router.
Reset the router for 30 seconds.
Power cycle the router.
open the setup page of the router using 192.168.1.1.
Try to setup linksys router.
Sep 23, 2011 | Computers & Internet
It has stopped connecting to the Internet. The cable modem and computer are fine, but the cable modem and the linksys no longer "talk" to each other. Other wireless connections in my vicinity work OK on...
Base from the description of your problem it seems that we need to reconfigure the router to work with your modem again and we need to do that manually using a computer connected wired to the router.
To do that follow these steps.
Connect the modem to the router and computer to router also, make sure all connections are correct.
Then power on the router , modem and computer and check all the lights on the router are fine and make sure power is solid green if those are fine access the router setup page.
From the computer that is wired to the router a\open internet explorer and type 192.168.1.1 and hit enter then that should ask for a username and password, just leave the user name blank and password is admin hit enter you should be now on the router page.
From there under SETUP tab look for a sub tab MAC ADDRESS CLONE , then enable that and clcik on clone pc mac and ten save settings and once its save power off the router and modem for 1 minute then after that power on the modem and then the router and check if internet is already working.
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
My modem is working perfectly on my notebook then i installed my Linksys router on the modem and router to my notebook. I turn on the power of my modem everything is light up then i power on my router,...
Wireless broadcast is usually the first thing to go when a router is failing. How old is your router? Try these steps:
Turn off computer
Remove power from router
Remove power from modem
Wait 2 minutes
Restore power to modem
Wait for modem to boot up and gain all signals
Restore power to router
Wait for router to completely powerup
Watch for wireless indicator light
Boot up computer, verify your wireless network is broadcasting
Connect
If you still can not get the wireless network to access the internet, try connecting your computer with an ethernet cable. If everything connects fine and you can access the web, it might be that your router is going bad and needs replacing.
Try running the ethernet cable from the modem to port #2 on your router. Then run the second cable from port#3 on the router to your computer. This effectively uses the router as a pass-thru and bypasses all its functions. If you are able to access the internet this way, you need to replace the router.
Jun 26, 2010 | Linksys Wireless-G WRT54GL Router
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
The network is working but I can't get the internet
If the internet is not working first thing to check here is the internet connection from your modem without the router, make sure that your computer can access the internet when computer is connected directly to modem, if no internet without the router you need to contact your ISP for that, but if there's internet without the router you need to reset and reconfigure the router.....if you have the setup CD of the router just run that to reconfigure it back.........
Aug 12, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
D-Link GamerLounge DGL-4300 Router (DGL4300) Logo
280 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
