Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Picture blanks out when there's a lot of white
My Sony has a problem with screens that are mostly white (such as the Wii eMail menu, or commercials that start all white).  It's quite bizzar but when thre is a lot of white the screen blacks out momentarily then cycles back on.  It doesn't always cycle out for the same time but average recover is <2 seconds.  The lamp is not going off as when it goes black there's still the screen glow.
  • 56 Answers
First I have a question for for you...Does it happen on all channels???I'm asking you this because if its not on all channels the problem may not be the tv set but the station that you are watching.The reason is that they have to transmit signal 1Vpp max and if its higher for some reason it makes interference with sound which your tv see as a mistake and protect circuit turn off LCD inside.The other thing is that your lamp time is over and you have to replace it because it can't provide enough light anymore and when "white" scene is on the screen the high voltage unit try to heat gas in the lamp but can't and protect is working again
Posted on Mar 23, 2008
Screen is white blank 2 inches on each side of picture.
Switch to the an input that is not being used. The bars are present, go into the menu and reset the tv to factory settings. If the bars are present it would indicate hardware failure.
If the blank bars are not present on the other input, something is going on with the cord, or a setting in your set top box
Nov 22, 2013 | Toshiba 42HP66 42 in. LCD Television
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
The wii console will play some games but not
if you have internet sometimes....the internet drive puts to much pressure on the wii so... it has a breakdown. :-}
Mar 09, 2010 | Nintendo Wii Console
Boot up Wii and only get a blank screen, Have sound
Make sure that you are connecting the RCA (Red/Yellow/White) cables into the standard input RCA slots on your TV/VCR. If you are plugging them into the standard output slot or an HDTV slot that is likely the problem.
Dec 19, 2009 | Nintendo Wii Console
My wii unit does't work. There is nothing but a black screen.
Hi.If the power light is green or orange and your screen remains blank, follow these steps.
1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2. Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved. If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired by a certified Nintendo service tech.
SYSTEM UPDATE
If your Wii console is currently connected on-line, you can download the latest Wii System Update by selecting the "Wii System Update" button from Wii System Settings menu. Downloading the latest Wii System Update will add the most current features to your Wii console. If you already have the latest update, on-screen messaging will indicate so after the Wii console searches the available Wii System Updates.
Oct 23, 2009 | Nintendo Wii Console
Game shows as loaded on the home menu screen but won't play.
It is because you need to do the following things:
unplgg the wii consol.
Then wait 10 minutes.
Plug back up.
Then if still shows call nintendo
Aug 29, 2009 | Nintendo Wii Console
Blank white screen sony DSC t77
To Power Reset the Camera, please remove the Battery from the Camera, press and hold the Power button for 30 seconds and then reinsert the Battery.
Another option: I took the battery out and I pressed Menu and Shutter button for 30 seconds and it worked! The screen is back!
Jan 05, 2009 | Sony DSC-T7 Digital Camera
Wii Start but the game didn't start, screen went black
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR?
  • The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
    • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
    • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
    • Look for inputs marked Audio and Video IN.
    • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
    • Do NOT connect your system to anything marked OUT.
  • My experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired.
Jul 11, 2008 | Nintendo Wii Console
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
