Taking front panel of an acer aspire e380
Have been looking for screws or snaps that hold front panel on an acer aspire e380 trying to get access to place intake fan
  • boonierat5 Feb 26, 2008
    thnx hemanth86, but i figured it out, the front snaps on and off
    for those of you wondering about adding ram i am running 3 gigs ok. the only way i could get it to run with that amount was to put 2 sticks of 512 g's at 667mhz then add 2 sticks of 1024 at 667mhz runs fine.. i did add a xfx 8600 gt 256 mb at ddr3 video card and it slipped in and worked right off,,,no problem. i am a little nervous about the 300 watt psu handling all this but so far so good.i have a 550watt ultra x standing bye, but the last time i got my machine back from acer they said they thought that psu was a problem for the mobo, between a rock and a hard place
    Problem Solver:
  • 5 Answers
Please try with acer for spare they might help u with this because the design of model r pc will be different thats better to call acer
Posted on Feb 26, 2008
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
How do I remove the front panel of Acer Aspire ASE380 desktop computer? They are not working.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Acer power button jammed
it seems to be a typical box PC, so I would try removing the side panel then look for some snaps on the front, and unsnap the front plastic bezel from the unit. (one side snaps, the other side is tabbed in with some plastic hinges that will just open as you pull the snaps back). once the plastic is off you should have access to the plastics inside the face panel.
Sep 18, 2012 | Acer Aspire SA20 PC Desktop
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
Reset bios on acer aspire e380
You can reset BIOS setting by CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
If the computer still does not boot, then it needs repair.
Thanks and regards,
Jitha
Dec 16, 2011 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
I have an Acer Aspire E380 desktop. Does it
It should not matter as long as the antenna is not surrounded by metal.
May 08, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Installing cd drive
Hey there beisong,
In many desktop computers you need to install the drive from inside the case and slide it outward along the runner. The piece of metal you are possibly referring to, will prevent it from sliding out too far from the inside. Alternately, but less likely, there may may some quick locking mechanism on the side of the bay drive which is in place and preventing your further movement inward. In this case simply remove, usually by twisting to one side or the other to release. It may be advisable to remove both side panels to ensure there is not one on the opposite side.
Good luck and let me know how it goes.
Nov 05, 2008 | Acer Aspire E380 ASE380-UD500A PC Desktop
Acer E380 - How do I change the DVD drive?
There are 6 clips on the inside of the case that hold the front cover. You will need to remove both the left side (easy side with two hand screws) and the right side (two philips screws).
Use a flat head screwdriver to pop the clips on each side (3 on each side) and the cover will come off.
Good luck.
Aug 16, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire E380 memory
Hi pimp69,
You can only use components compatible with Aspire series computers. Before you choose new components, please ask your authorized Acer dealer whether the part will operate within your Aspire series system. This is noted in your manual pg. 6.
Compatible memory for your Acer. Don't forget your Acer uses an intergrated graphics card that uses your system memory to function.
http://www.google.com/products?hl=en&q=Acer+Aspire+E380+memory&um=1&ie=UTF-8
Good Luck & Kind Regards.
Mar 19, 2008 | Computers & Internet
HELP ME PLEASE!!!!!!!!!!! I CAN'T GET IT APART!!!!!!!!
Have you removed the battery, and checked for screws there? Looked under the memory cover. Chgeck the the two halvers of the shell are not 'snap' together?
Jun 24, 2007 | Acer Aspire 3003WLCi Notebook
Computers & Internet Logo
257 people viewed this question
Alun Cox
David Payne
David Payne
