Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Power Head for Electrlux Oxygen Ultra
The unit arrived with a bad power brush bearing. I kept using it anyway, but by now the brush has cut through the plastic slider. The ends of the slider are ripping carpets, so it is time to replace the brush, bearings, and slider or, alternatively, the whole head. Where can I buy a new head? Thanks,
MV
mvida2@yahoo.com
  • 75 Answers
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Posted on Feb 26, 2008
I can't get the air filter door to shut on my Electrlux oxy 3 vacuum.
Is there one of the attachments (If this unit stores attachments under this door?)-- is one of the attachments just a little out of its 'proper' spot?
Sometimes generic filters need to e trimmed down, to fit better than manufacture specific ones--
Can you see where it might be hitting?-- like by putting grease or some indicator on it, and seeing where it might be rubbing the lid?
Hope this helps-- if not, tell us more-- so we can help better--
Mack B
Jan 25, 2011 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My oxygen will not pick up pet hair out of the. The brush rotates
Your brush may not be spinning try pressing the reset button on the back of the power nozzle, it that does not work you may need to change the belt.
Bob
eVacuumStore.com
Mar 18, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Eletrolux power head
Usually you will find a brush assembly which includes the bearings. You could also be hearing the belt jumping across the brush gear if the belt is bad. If you order the parts online, you may want to get a brush and belt, since a belt won't be that much more money anyway. Aftermarket Aerus (formerly Electrolux) parts can be suspect sometimes, so I would suggest finding a dealer. You can go to their website to find the closest store. aerusonline.com Good Luck!!
Oct 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
How to clean the power brush on the miele vacuum. Is the brush removable? If so how do you remove it?
Greetings from GoVacuum.com,
Miele canisters have 2 different types of power brushes. The first, and most popular is the Miele SEB 217, and 213 Power heads. To remove the brush, follow these instructions.
On the bottom of the power head there are 2 yellow (older models it is black) plastic screws. You can remove these screws with a phillips head, or flat head screw driver. Simply unscrew these two screws. You do NOT have to remove these screws, just unscrew them to where they are loose enough to remove the bottom plate.
Once you have unscrewed the plastic screws, simply pull the bottom plate up and off of the power brush. You will notice the belt on the left hand side of the brush. Simply pull the brush up, and un hook the belt from the brush;
Now that you have unhooked the brush from the belt, you may thoroughly clean the brush, and un wrap any hair or thread that is wrapped around the brush. You will notice on the roller brush itself there are two indentions on both sides of the brush that run the entire length of the brush. You can take a knife or scissors and run them down the brush on both indentions, which will help you remove the stubborn debris wrapped around them.
Also you'll notice on both sides of the brush that there is a yellow bearing cap on both sides of the brush. You may pull these bearing caps off, and remove any debris that is around these caps. You may also lubricate these bearings with grease or WD-40, to ensure the brushes spin fluently.
After you have cleaned the brushes and bearings, insert the brush roller back through the belt, and into the power brush. You'll notice that the bearing cap will have two sides. One side of the bearing cap has 1 groove in it, the other side has 2 grooves.
When you reinsert the brush back into the power brush, you may lower the roller brushes if the machine has been used a lot. If the roller brush is older, you will want to re insert the brush with the side that has 2 grooves facing upwards, and the side with 1 groove in it, facing down. In the first picture above, you will see that the side with 1 groove is facing upwards and is visible to the camera. The side with 2 grooves is facing down. This is because this brush is new. If your brush is older, you will want to reverse that, and have the side with 2 grooves facing upwards. When the brush is back into the power head, simply put the bottom plate back on, (IMPORTANT! Make sure that in the front of the machine the bottom plate is completely hooked onto the front of the power brush, there should NOT be any space in the front) Once you have screwed the plastic screws back into the power brush, in the front of the power head, push the bottom plate upwards to make sure there it is fastened tightly in the front.
I hope this helps you. If you have the larger, less popular SEB236 power brush, just send me an email, I'd be happy to walk you through cleaning the brush on this one also. If you have any questions about this repair, please feel free to email with any questions, I really enjoy sharing my knowledge, and passion fixing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Miele Vacuums
Electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Sep 01, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power head stops and starts
Sounds like there is definately something stuck inside it. You;ll need to dismantle the floor head carefully using a screwdriver. Make sure your machine is switched off though if it is a power head and not an air turbine turbo head. Once inside check the main roller brush as well as the side caps as these can become clogged. Also check the main dirt channel leading to the pipes of the vacuum.
Dont forget to rate, thanks.
May 25, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The roller brush will not stay on-& the cord rewind is stuck on
There is a reset on the power head, does the wand fit tight in the neck of the power head, if not you may have a problem there, either the wand or the neck. If the lever is stuck on, then it is jammed or broke, maybe a spring is out of place, in any event the canister will have to be taken apart to see what the problem is.
Feb 19, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
191 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
