Laptop sound hi a icon on right of my taskbar say that i dnt have ANY audio input output device what should i do????????
    Problem Solver:
  • 5 Answers
Go to mycomputer rightclick on mycomputer go to manage in manage goto device manager and chech it where the sound driver is installed properly if not try to update the driver r reinstall the driver then it works.
Posted on Feb 26, 2008
  • 51 Answers
Check Control panel - >System -> Hardware ->Device manager ->sound video an game controllers.and make sure there is no exclamantion mark and also check other devices to see if you require any further audio drivers..
maybe youhave re-install your audio drivers
Cheers!!!
No audio output device is installed on my acer aspire 5535 laptop
which operating system ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Sep 24, 2012 | Acer Aspire 5535-5050 Notebook
I've lost the sound and the volume icon on my taskbar of my VGN-NR38E
- Check if the audio driver is installed and enabled in device manager.
- if audio driver has a exclamation point then reinstall the audio driver
- if the audio driver has a red X, right click it then choose enable
- got to control panel. check under sounds and audio devices, put a check on place volume icon on taskbar, uncheck mute
Mar 26, 2011 | Sony Computers & Internet
I have lost all audio on my laptop after watching a film on youtube.When i right click the Sound icon on the taskbar, i cannot instruct the laptop to use the internal speakers as it says "No Audio...
The joys of downloading from an unsafe source.
The PC should reinstall sound drivers automatically when it boots, if not go to the manufacturers web site and download a fresh sound driver for the sound card.
Mar 16, 2011 | Computers & Internet
Have a broken Headphone input on Lenovo y 550 (Vista). Is there a software shut off for this input ,that will leave speakers and USB headphones still functional ? I have noted that when one rests ones...
You can simply right click on the Audio icon on the lower right side of the screen or on the task bar and go to your Audio Properties where you can disable audio devices such as the headset, or microphone or simply input/output audio devices.
Try It! ?
Aug 14, 2010 | Lenovo Y550 Notebook
No audio output device for compaq F700
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application
Aug 09, 2010 | Compaq Computers & Internet
I DONT HAVE SOUND ( AUDIO OUTPUT DEVICE IS NOT INSTALLED)
Check out either the audio drivers (start > settings > control panel > system > hardware > device manager >check for exclamation mark in front of the audio device) and update if nessersary,
Or the audio mixer levels from the audio related icon at the taskbar. In case it's missing go start > settings > control panel >sound devices > mark the checkbox "volume icon at the taskbar"
After the above you will be able to hear audio from your computer but in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 08, 2010 | Toshiba Satellite L45-S7409 Notebook PC
Please....my emachines d725's microphone isn't working..help please!
After downloading every possible driver and tweaking every possible adjustment I have come to this conclusion: There is NO built-in microphone on the eMachines D725! Oh, the Device Manager will show it, all right but I assure you, there is no built-in device that can pick up sound on that laptop model. You'd think that a laptop, albeit a budget on, with a built-in webcam should also have an accompanying built-in mic for messaging and calls, but it doesn't. The mic may have fallen by the wayside during the cost-cutting sessions, along with the 3rd and 4th USB ports. Your only options are to connect an external microphone or to trade the D725 for a real laptop.
Mar 01, 2010 | Computers & Internet
Volume icon on taskbar says no audio output device is installed
Hi there.
You need to install the audio drivers so you hear the audio.
Please post the make and model of the computer so we can direct you to the appropriate driver download.
Regards
May 26, 2009 | Gateway Computers & Internet
Cannot detect sound input (mike not working with any headph)
Right click in the taskbar,then click properties,then click notification area and tick the volume box. it should go back to the tray. Then right click the volume icon and goto recording devices,choose the device you wish to use and then click properties. Ensure that it is enabled. Then goto your yahoo settings and select the cam/audio settings and choose the device you wish to run in yahoo. Make sure you check the box 'ALLOW OTHER PROGRAMMES TO USE THIS DEVICE'
Oct 25, 2008 | Compaq Computers & Internet
Laptop volume broken
go to control panel/sound and audio devices/audio and check your sound card also check place an audio icon in the taskbar (you might uncheck it and check it again)
Apr 14, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
