Question about HP Pavilion dv6000z Notebook
3300 averatec dont power on and usb port not working
I already checked the device nanager the usb says is still working but when use flasdrive its not working..already tried troubleshootng..also the keypad is not working, to use it i still have to press shift to use the letters..and sone letters when i press is not working. what will i do? is there any repair shop in the philippines?? i fro the philippns> pls eail fab_hetty@
  • ufial Aug 03, 2008
    my Averartec 3300 doesnt accept USB Devices and mouse. Everything was fine, till I adapted a 160 GB flasdrive. already did the usal things as unistalling i th edevice manager and so on.
  • 100 Answers
If u have all drivers then ur harddisk do format and install windows and all drivers.
Posted on Feb 26, 2008
I need to reinstall my 3300 serries Averatec however I was not supplies a CD when purchased it
try the Averatec if you still have warranty on it. ask for a recovery cd. if your out of warranty already. try this website, this might help you. .
Mar 29, 2010 | Computers & Internet
I have an Averatec all in one and how do you connect the wireless mouse?
Wireless mice have two parts. The mouse which needs regular battery charging and the receiver. The receiver is a USB device that plugs into any of the USB ports on the back (near the DVI port) or on the side below the audio jacks. Plugging into a USB hub is an option but can give an extra area of trouble-shooting when it fails.
If the port doesn't work, try a different one. Check that the USB ports aren't disabled for security or power-savings. Make sure the receiver is showing that it is active and that the mouse has good batteries.
One of the biggest issues can be waking from sleep with a USB device. This is changed in the advanced power savings in Windows.
I hope this helps.
(since my wired mice need to be replaced every few years, I suspect wireless mice have similar failure issues.)
Feb 11, 2010 | Averatec D1002UHCE-1 All-In-One Intel...
USB ports stopped working
go to the Averatec support driver page and download new drivers for the USB. Sometimes these are listed as "chipset" drivers, which is a set drivers bundled into one.
below is a link to where you can download files
Aug 30, 2009 | Averatec 3200 Notebook
Does the hard drive interchange with other Averatecs?
Swapping hard drives only works if the hard drive is swapped into an identical computer with the same device configurations, CPU and RAM etc.
The best way to copy or recover data from a working hard drive is to insert the hard drive into an USB hard drive adapter and plug it into a working computer's USB port. You should see this drive as an external hard drive and you can then copy or backup the data onto the computers hard drive or USB memory stick etc.
May 13, 2009 | Averatec 3150H Ultra Thin Notebook PC With...
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Feb 01, 2009 | Averatec 3200 Notebook
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
I have an Averatec model#3150p pc notebook.It has a 3 port usb hub but only 1 port works. i.e.:When I plug a device into the 2nd or 3rd port I get error message saying the device has a problem.(unknown...
Dear Friend..
Go to Control Panel=>System => Harware=> Device Manager. Under the "Universal Serial Bus Controllers" delete all USB root hubs & controllers/ ports & then Action=> San for hardware changes That shall freshly install the USB ports on your system & shall work.
Best of Luck..
Jul 10, 2008 | Computers & Internet
Laptop Averatec 3200 PC Notebook
Try having the problem devices turned on and plugged into the USB port(s) and then start or restart your PC.
This should cause Windows to recognize them and install drivers if available from its library.
It may also ask for an installation disk if it cannot identify the device.
Jun 30, 2008 | Averatec 3200 Notebook
Averatec USB ports
Hi, A couple of things you can try: 1. In your Device Manager, un-install all USB instances then reboot. Win XP will auto detect and auto install back the USB drivers; 2. On reboot, again in your Device Manager, all instances of USB Root HUB, right click, click on Properties, Power Management tab, un-check "Allow the computer to turn off this device to save power." 3. Download, install and use to format flash drives the HP Drive Key Boot Utility (cp006049.exe) available at If for some reason none of the above will for you, you may need to install an external/powered multi-port USB 2.0 Hub. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | Averatec Notebook
HP Pavilion dv6000z Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
