Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune washer detergent department that is on the lid
After you put the detergent in the compartment and you wash several loads the detergent seems to build up in this compartment. Is there anyway to avoid this and is there anyway to get rid of the build up already in it? I clean it weekly with bleach and detergent like recommended and use HE detergents. Thanks
  • 749 Answers
Use vinegar in cleaning it! soap, as it is made of mostly soda dissolves in vinegar.
also vinegar helps remove bad smell on the machine cause by residue dirt from clothes.
Posted on Feb 26, 2008
I have a maytage neptune washer mah8700a that displays "suds". It runs several additional rinse cycles before completing the wash. Have switched to tide and run much less soap. Tried an empty load on
Are you using detergent that is rated for HE (high-efficiency) washers? They are manufactured to require less per load and produce fewer suds. Conventional detergents in HE washers will result in over-sudsing.
Dec 22, 2014 | Neptune Washing Machines
Where does the detergent go?
lift up the cap on the middle of the bit that is in the middle under the lid
Nov 22, 2013 | Maytag Neptune MLE2000A Front Load Stacked...
Silly question - where do you add the detergent?
Often you will find the detergent dispenser very close to the dispenser for the softener. Mine is a separate container within the same "pullout" drawer that holds fabric softener. If you still are not sure, then find the model number of your washer and google it with the term, "user manual". Most are available online as a PDF
Where do you put the soapin a maytag neptune
On the neptune washer, on the top there is a dispenser on the left hand side, lift up the lid, there will be 3 compartments, the compartment closest to the control panel is the one you put the soap into, the middle compartment is for bleach, the other one is for fabic softner.
Aug 15, 2012 | Maytag Neptune MAH6500A Front Load Washer
How do I put in the detergent?
Lift the cover on the top surface and place the detergent in the rear compartment of the bin.
If this is in a stack configuration, you simply add the soap on top of your load of clothes..
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune wash machine. Clogged detergent compartment
This may not help much but here is the Maytag Neptune installation and service manual.
You may be able to better troubleshoot your problem with this.
It's a PDF document that may take a couple of minutes to load.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
Sep 28, 2009 | Kenmore 43142 Front Load Washer
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
Where do I put detergent?
As you face the front of the washer on the left the first receptacle is for the softener, the second for the bleach and behind that is an open area ("pit") where the detergent should be dposited to be perfused by water at the beginning of the wash cycle.
I had to label these areas since the lid normally covering this area was the first thing to break on this washing mashine.
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
White Plastic From Washer
Sounds like pieces of the detergent drawer might have cracked and fallen off. Check the drawer and see if you need to replace it.
Nov 01, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag Neptune FAV6800AW Top Load Washer Logo
245 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
