Sony wega tv kv36fs100
Dead after 5 sec,high voltage drop down to zero after 5sec.
    Guru:
  • 1,894 Answers
Hello sir
Posted on Feb 26, 2008
  • dewan nafees ahmed Feb 26, 2008
    your capacitors has been blowed up
    change it sir.
Samsung TV no sound no picture backlight on and off
Check voltage at the power board. After 120 volts enter the TV, there is fuse then a small high voltage transformer, then a 100 uf rated at 450 volts capacitor. There should be 390 volts DC at the capacitor. Without this 390 volts the TV will shut down.
Dec 28, 2017 | Samsung Televison & Video
Voltage drop. When in parked I rev up the engine, when it comes down, the voltage drops from 14 to 10, for about 5 secs. I think the truck will cut off but it immediately comes back up to 14.
If the alternator is weak, and you have accessories like the headlights or blower motor running, and the RPM drops below 600, the voltage could be below 12. It would depend on the load, RPM, and several other factors.
Feb 12, 2014 | 2000 GMC Yukon XL
My 06 nissan frontier with flat tire light on even all tire are 35psi or more .
Step 1:
You could have a bad tpms sensor in one of the tires here's how to check it
Step 2:
Reading TPMS codes and clearing them
There is a simple procedure to perform a self diagnostic and clear the codes.
1) Turn IGN switch to ON.
2) Locate the TPMS warning check connector. It is a single loose wire with a connector located under the dash next to the steering column. It may be bundled with the OBDII diagnostic connector.
3) Using a suitable piece of bare wire inserted into the connector (a paperclip will do), momentarily ground the wire to the chassis.
NOTE: If you are uncomfortable doing this, then don't. You could damage your vehicle if the wrong wire is grounded.
Step 3:
4) The TPMS low tire pressure warning light will blink error codes as follows:
5sec. ON - 5sec. OFF
Long (1 sec) blink = First digit (2 blinks = 2)
Short (0.2 sec) blink = Second digit (ie 3 short blinks = 3)
There is a 2 second pause between multiple codes.The cycle will keep repeating starting with 5sec. ON
Codes:
15 - Front LH tire pressure drops to 26 psi or less.
16 - Front RH tire pressure drops to 26 psi or less.
17 - Rear RH tire pressure drops to 26 psi or less.
18 - Rear LH tire pressure drops to 26 psi or less.
21 - Data from front LH transmitter can not be receive.
22 - Data from front RH transmitter can not be receive.
23 - Data from Rear RH transmitter can not be receive.
24 - Data from Rear LH transmitter can not be receive.
31 - Checksum data from front LH transmitter is malfunctioning.
32 - Checksum data from front RH transmitter is malfunctioning.
33 - Checksum data from rear RH transmitter is malfunctioning.
34 - Checksum data from rear RH transmitter is malfunctioning.
5 short blinks - System is OK.
5) To clear the codes, turn the ignition OFF.
Feb 27, 2013 | 2006 Nissan Frontier
DEAD JUST STANBY LIGHT FLASHING AND HIGH VOLTAGE COMING AND COMING OUT A 1 SEC AFTER.
If the high voltage comes up and goes right down something in that area is either shorted , open or bad---only thing in power supply that could cause this is if the main voltage (130 volts plus to the high voltage area is HIGH---the high voltage will go excessive and shut the set down--xray protection.
Oct 25, 2012 | Toshiba 27A60 27" TV
Cisco 876 doesn't work at all
The power adapter maybe faulty. Test the voltage on the plug that connects to the router with a multimeter, the voltage should be slightly higher than the voltage that is printed on the label on the adapter.
If the voltage is low or zero then the adapter needs to be replaced.
May 19, 2012 | Cisco 876 ADSLoISDN Sec Router
Fuse keeps blowing in hotpoint microwave
The magnetron is the other issue, high voltage diode will sometimes crack causing a high level short, the capacitor developes a dead short across the 2 points, the power transformer almost never fails, "very rare"
Apr 08, 2012 | Hotpoint RVM1635 Microwave Oven
I have a 99 VW Golf and the battery went totally dead. When I tried to jump it the cables started smoking and the wires melted. A volatage meter registers zero when the battery is connected to the car...
At 5 Volts the battery is totally cactus (a fully charged battery should read above 12.6 V) and from the description of hot melting wires appears the battery has a dead short between cells. Try a new battery and check battery terminal voltage before and after connection, with every thing turned off. If terminal voltage drops more than 0.2 V it would indicate excessive current draw by a faulty component. You may have to have the electrical system checked by an auto electrician to determine if there is any other faukts in the system.
Dec 11, 2010 | 1998 Volkswagen Golf
ST423E SYMPHONIC 23 TV 2.1
set is shutting down. most likely in high voltage circuit feeding back to the power on rely.
May 26, 2008 | Televison & Video
Samsung SyncMaster 740N 17" auto adjustment locked
I just had my Samsung 740N LCD monitor auto adjustment lock 2hours ago.
But i found this cool solution at
www.fixya.com
"Press down
the menu button(1st button on the left) for 5sec or until the menu display gone?"
and it works for me. Hope it will work on you
Thanks
http://www.fixya.com/
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
