Question about ViewSonic NextVision M2000E PC Desktop
Lost Ethernet on Win XP MCE upgrade
I upgraded the OS in my Viewsonic M2000e from Windows XP MCE 2004 to the 2005 edition. In the process, I lost Ethernet connectivity. The Ethernet is integrated into the motherboard, so I just need to reinstall the driver, but that's the problem. The motherboard is OEM made by Intel for Viewsonic, so Intel doesn't support it. I'm about to contact Viewsonic, but from what I gather from the comments on this forum, that won't be a helpful experience. All I've got is the BIOS ID: BB84510A.86T.0021.P02. Anyone have a similar problem, or can point me to the correct driver?
I have two of these computers.
the network driver you want is one for "intel pro 100 VE"
go here for information on this driver.
http://www.intel.com/support/network/adapter/pro100/pro100ve/
Iam lookin for mother board support as well.
good luck in your hunt.
Posted on Feb 14, 2009
    Sergeant:
  • 349 Answers
Hi glycogenic open up the case and look for a motherboard model number on the motherboard (it could be anywhere) but sometimes in large print, then do a search with it on the net
ie Ethernet drivers for (insert mobo number) running XP MCE 2005. or something similar.
good luck with that
Terry
Posted on Feb 26, 2008
Software upgrade
Hi!
Well, win xp is absolutly more fun as OS then win 2000:)
To upgrade to win xp will be no problem since Toshiba have drivers for ir. To upgrade to VISTA will...or can give you problem since there arent any drivers for that Tecra S1.
If u deside to upgrade to win xp, here is all the drivers u gona need to do it:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380605&rpn=PT831U&modelFilter=S1&selCategory=3&selFamily=1073768664&selModel=380605%7CPT831U
Good luck
Dont forget to RATE me
Nic
Mar 12, 2009 | Toshiba Tecra S1 Notebook
Tip
Upgrade Windows XP to Windows 7 - it is possible!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows XP Professional
Tip
How to Upgrade Windows 98 or Windows Millennium Edition Profiles to Windows XP...
This guide describes how to upgrade a Microsoft Microsoft Windows 98-based, or Microsoft Windows Millennium Edition-based client that has user profiles to a Microsoft Windows XP-based client.
The following steps enable the Windows 98 and Windows Millennium Edition (Me) profiles to be retained throughout the process.
Your best method to retain the profiles is to join the domain during the upgrade installation process.
Otherwise, you must use a workaround method to transfer the profile information over to the Windows XP profile.
During the upgrade installation process, at the networking section, the administrator is offered the choice to join a domain or a workgroup.
If you join the domain at this juncture, you ensure that all the existing profiles are migrated successfully to the Windows XP-based installation.
If you did not join the computer to the domain during the upgrade process, you must use the following workaround method:
Join the upgraded computer to the target domain.
All applicable users must log on and log off (which generates a profile).
Copy the appropriate Application Data folder from the Windows 95, Windows 98, and Windows Me profiles to the newly created user profiles.
on Jul 03, 2010 | Computers & Internet
I recently Upgraded from Windows XP to windows 7 when Windows 7 was finished intalling internet connection did not work. Before upgrading everything worked fine.I did troubleshooting and it said ''No...
Hi
Win 7 is extremely touchy about network drivers. I didn't see your computer model listed but you'll need to log onto your computer manufacturers support page and download the Win 7 drivers for the network. Since your internet connection doesn't work right now I'd suggest another machine, if you have one or go to your local library with a Flash Drive and download the drivers to that. Good Luck
Mar 07, 2010 | Microsoft Windows XP Media Center Edition...
Compatibility of vista os with hvr-1100
yes it is,
Supported OS: Windows XP Windows XP MCE Windows Vista Windows Vista MCE
Jun 22, 2009 | Hauppauge WinTV-GO PLUS PCI TV Tuner...
DRIVERS Problem
here is the link... download the drivers and install it...
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3360308
Sep 20, 2008 | Compaq Presario Notebook
Orite CS780 Multiple Digital Camera Driver for Windows Vista
I have lost my driver please let nme know how to down load or how to get it.
Said
May 05, 2008 | Orite CS780 Digital Camera
ViewSonic NextVision M2000E PC Desktop Logo
207 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
