I have problems in installing the wireless card in my new notebook...
it seems that after downgrading the OS from Vista to XP-Pro the
wireless card has not been recognized...
the model details:
Compaq Presario C700T CTO Notebook PC ...
PLEASE
help me by supplying the info on the model of the WIRELESS adapter/card
and the compatible DRIVER for this particular notebook...
I have DOWNGRADED to XP-pro system (the original OS was Vista Home)...
The problem is that I don't see any 'wireless' adapter in
:device manager>network adapter... the only device I see there is a
"Realtek RTL8139/810x Family Fast Ethernet NIC"... I tried with
different BroadCom and Intel PRO drivers... without any luck so far...
in some cases when I installed some WLAN drivers the system is
recognizing a new SM Bus Controller!
The OS originally
(preloaded) was Vista Hole Basic... and currently I have removed that
and installed XP-Pro SP2... the wireless was working fine in the
Vista... but now after Xp installation it is inactive...
The notebook has a wireless on/off button. when it is on it shows blue
light, when off shows amber/orange light. After I installed XP, I tried
to turn the switch ON, but it is not turning on (remained in
amber/orange state)... originally in Vista... I was able to turn it on
or off by pressing the button...
Now, in XP, when I press the button I get a message in HP wireless assistant that the Adapter is Disabled!
Here is the output from HWIDS:
PCI Devices
PCI\VEN_10EC&DEV_8139&SUBSYS_30D9103C&REV_10\4&3B3A03B5&0&08F0:
PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_F3\3&B1BFB68&0&F0 : Intel(R) 82801 PCI Bridge - 2448
PCI\VEN_8086&DEV_2815&SUBSYS_00000000&REV_03\3&B1BFB68&0&F8 : PCI standard ISA bridge
PCI\VEN_8086&DEV_2828&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&FA : Standard Dual Channel PCI IDE Controller
PCI\VEN_8086&DEV_2830&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&E8
: Standard Universal PCI to USB Host Controller
PCI\VEN_8086&DEV_2831&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&E9
PCI\VEN_8086&DEV_2832&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&EA
PCI\VEN_8086&DEV_2836&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&EF
: Standard Enhanced PCI to USB Host Controller
PCI\VEN_8086&DEV_283E&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&FB : SM Bus Controller
PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_03\3&B1BFB68&0&E0 : PCI standard PCI-to-PCI bridge
PCI\VEN_8086&DEV_284B&SUBSYS_505114F1&REV_03\3&B1BFB68&0&D8
: Microsoft UAA Bus Driver for High Definition Audio
PCI\VEN_8086&DEV_2A00&SUBSYS_00000000&REV_03\3&B1BFB68&0&00 : PCI standard host CPU bridge
PCI\VEN_8086&DEV_2A02&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&10 : Mobile Intel(R) 965 Express Chipset Family
PCI\VEN_8086&DEV_2A03&SUBSYS_30D9103C&REV_03\3&B1BFB68&0&11 : Mobile Intel(R) 965 Express Chipset Family
14 matching device(s) found.
USB Devices
USB\ROOT_HUB\4&418D2B0&0 : USB Root Hub
USB\ROOT_HUB\4&9AF5AA5&0 : USB Root Hub
USB\ROOT_HUB\4&F4F670&0 : USB Root Hub
USB\ROOT_HUB20\4&33034A12&0 : USB Root Hub
USB\VID_0A81&PID_0203\5&22EA2E08&0&2 : USB Human Interface Device
USB\VID_1058&PID_0702\575845583036353838383037 : USB Mass Storage Device
USBSTOR\DISK&VEN_WD&PROD_1600BEVEXTERNAL&REV_1.02\575845583036353838383037&0: WD 1600BEVExternal USB Device
7 matching device(s) found.
Input Devices
HID\VID_0A81&PID_0203\6&1B43D1C3&0&0000 : HID-compliant mouse
1 matching device(s) found.
ACPI Devices
ACPI\ACPI0003\2&DABA3FF&0 : Microsoft AC Adapter
ACPI\AUI0214\4&2FFE84EA&0 : PS/2 Compatible Mouse
ACPI\FIXEDBUTTON\2&DABA3FF&0 : ACPI Fixed Feature Button
ACPI\GENUINEINTEL_-_X86_FAMILY_6_MODEL_15\_0 : Intel(R) Pentium(R) Dual CPU T2330 @ 1.60GHz
ACPI\GENUINEINTEL_-_X86_FAMILY_6_MODEL_15\_1 : Intel(R) Pentium(R) Dual CPU T2330 @ 1.60GHz
ACPI\HPQ0006\2&DABA3FF&0
ACPI\INT0800\4&2FFE84EA&0 : Intel(R) 82802 Firmware Hub Device
ACPI\PNP0000\4&2FFE84EA&0 : Programmable interrupt controller
ACPI\PNP0100\4&2FFE84EA&0 : System timer
ACPI\PNP0103\4&2FFE84EA&0 : High precision event timer
ACPI\PNP0200\4&2FFE84EA&0 : Direct memory access controller
ACPI\PNP0303\4&2FFE84EA&0 : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
ACPI\PNP0A08\2&DABA3FF&0 : PCI bus
ACPI\PNP0B00\4&2FFE84EA&0 : System CMOS/real time clock
ACPI\PNP0C02\4&2FFE84EA&0 : Motherboard resources
ACPI\PNP0C04\4&2FFE84EA&0 : Numeric data processor
ACPI\PNP0C09\1 : Microsoft ACPI-Compliant Embedded Controller
ACPI\PNP0C0A\1 : Microsoft ACPI-Compliant Control Method Battery
ACPI\PNP0C0C\2&DABA3FF&0 : ACPI Power Button
ACPI\PNP0C0D\2&DABA3FF&0 : ACPI Lid
ACPI\PNP0C0E\2&DABA3FF&0 : ACPI Sleep Button
ACPI\PNP0C14\0 : Microsoft Windows Management Interface for ACPI
ACPI\THERMALZONE\TZ01 : ACPI Thermal Zone
ACPI_HAL\PNP0C08\0 : Microsoft ACPI-Compliant System
ROOT\ACPI_HAL\0000 : ACPI Multiprocessor PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
I'm sorry to say that did not help to identify which card is installed in the system. Make sure the laptop is powered off and closed. Flip it over, and you'll see several covers that you can remove. Behind one of them is the wireless card - it will have at least one, and probably 2 wires connected to it. Read the model number and post that. It will be an Intel PRO/Wireless card, or an Atheros AR5007, or a Broadcom Wireless card. Once we know which one, we can then probably find the correct driver for it.
Thanks.
Assuming it is the Atheros chip as Derek believes, this should be the driver:
http://members.driverguide.com/driver/de...
I have just been through this nightmare on a new C700t. The only wireless driver that would work for me was for the Atheros AR5006x chip and downloaded from a site in Czechoslavakia!
http://www.atheros.cz/download.php?atheros=AR5006X&system=1
I used the Version 5.3.0.56 which works just fine except that the blue/amber LEDs don't toggle as you turn the WiFi on and off. I guess I can live with that... (I read somewhere that this feature is a vendor supplied mod to the driver).
Derek
Bagaimana caranya agar kt bs mendapatkan devices ACPI\SNYA008\4&276552DE&0
Friends,
Compaq Presario 700 PC Notebook's main problem is audio driver for win xp.
For Audio driver software you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
FYI- For any of you downgraging a Compaq Presario C700T CTO to Windows XP, this solved my audio driver problem. I can now control the volume settings and my headphones work correctly as well.
Conexant SmartAudio 221:
http://www.mediafire.com/?dg0cmmkm4y4
Use this for audio.Unzip to a folder.Run installer.if it errors use device Manager
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect,
Install from a list or specific location,
Don't search I will choose the driver to install,
In the list of common hardware types, scroll down and select Sound, Video, and Game controllers.
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".Ignore XP when it complains.
Reboot.
SOURCE: I need support dirver of fujitsu fmv7220
Try the computer manufacturer's website - look for drivers, support or downloads.
SOURCE: Download Realtek RTL8139/810x NIC Driver
Hi
Think you can download it from here
http://www.realtek.com.tw/Downloads/downloads
Hi Philster,
Thank you so much for your valued input. The information about the product number of my notebook is:
p/n: GY394AV
Other information:
System Model:
Hewlett-Packard Compaq Presario C700 Notebook PC F.24
System Serial Number: CND8073257
Board: Hewlett-Packard 30D9 83.1F
Your help is highly appreciated...
Thanks in advance
i have compaq c702tu notebook and i am not able to connect internet wireless.
plz help.
think
We have purchased a Compaq Presario C755TU Notebook and having same problem. Infact I've not got any driver neither for vista nor for win xp with this laptop.
After purchase I sent mail to hp support regarding drivers for this note book. Here are there reply.
From your email, we understand that you are looking for the drivers of windows XP Operating System for your Notebook PC.
In this regard I need to share with you that the notebook has
been tested with Windows Vista Operating System. It has not been tested
with Windows XP operating system and hence it might not be compatible
with it. HP recommends Windows Vista Operating System with the
notebook. Therefore, it is requested to install Windows Vista with the
notebook as it has been tested with it.
We would be able to provide the drivers for Windows XP Operating System
if it will be available on HP website. Otherwise I would request you to
take the help from Microsoft.
However, I am providing you base model drivers for your notebook model
on the "best effort" basis. It may or may not work. Please visit below
mentioned web link in order to download drivers for Windows XP
operating system.
1. Audio driver
You need to first install Microsoft Universal Audio Architecture (UAA) Bus Driver from the below web link:
http://h20000.www2.hp.com/bizsupport/Tec...
After that install Conexant High Definition Audio Driver:
http://h10025.www1.hp.com/ewfrf/wc/gener...
2. Modem driver
3. Ethernet driver
4. Display driver
5. Wireless LAN Driver
6. Touchpad driver
7. Quick Launch Buttons
[NOTE: In case the web link does not open up, kindly copy and paste it
into the address bar of the web browser on your system and click on GO.]
If you need any further assistance with the same from my side please
feel free to get back to me, I shall be more than happy to assist you
further.
Thank you and have a wonderful day.
Everything is working fine except wi-fi.
I'm still searching a solution for wifi driver for Compaq Presario C755TU Notebook.
Jitendra Manaswin
c518la
audio driver cannot dissapear
same here...i've downloaded all the wireless drivers i can find..but the the wireless device is still not working, and the wireless light cannot be turned to blue...
Serial: CND8251HTO
I have wireless and audio problems
same problem
same problem of switch but it is working even if lit glowing amber
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC" problem
please help me to sort out this problem as soon as possible
ACPI\HPQ0006
