Question about Nintendo DS Lite Console
Kracken How do I kill it. I've been stuck for days and can't figure it out. Scrum
    Problem Solver:
  • 4 Answers
Is scrumaxis(www.scrumaxis.com) company good for corporate training?
The information on website is good & easy to understand
Jan 31, 2015 | Computers & Internet
How to tune up my scrum multicab
What kind of a device is this?
Jan 05, 2015 | Computers & Internet
Why does my phone only hold a charge for a day without using it?Wx416
One time mine would kill the battery in only a half day.
I turned it off and rebooted it, and it's been fine ever since.
Only thing I can figure is something was running in the background that was using up the battery.
Jul 01, 2014 | consumercellular.com
What is a scrum?
I was able to find for you a great definition of a scrum from the Washington State women's rugby organization website. They define a scrum as:
"This is the most unique aspect of rugby (see our pictures page for a visual). It consists of the eight forwards on both teams and occurs after a rule infraction such as a forward pass. Essentially what happens is the eight players bind on to one another while the front row binds on to the other team. The two packs then push on each other while the ball is thrown in by the team which was not responsible for the penalty. The ball is then heeled (kicked backwards) by the forwards until it pass through the back of the scrum."
For more useful rugby info, check out their site: http://womensrugby.wsu.edu/faq.aspx
Feb 06, 2013 | Rugby
Yamaha majesty 125 2004 won't start! The engine
Hi, Mlt1937 and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
Yamaha YP125 YP250 YP400 repair manual Download Manuals Technical $10 cheap
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf Free
OEM parts for Yamaha
YAMAHA MAJESTY YP125E Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 23, 2017 | 2007 Yamaha Majesty 125
Kenmore Elite LD Error
LD means long drain. First check to make sure that there is nothing stuck inside your drain hose. The next thing to check is your pump. lean the washer back and locate the pump. Next take it loose and clean out any debrit inside it. That should take care of it. If not check your lid switch.
Nov 17, 2008 | Washing Machines
Nintendo DS Lite Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
