Question about SanDisk Sansa e200 MP3 Player
Cannot load music to sansa
I can load and play music from a memory card, but i cannot load or play music from the drive on the device itself
  • 1 more comment
  • Chillz Mar 02, 2008
    Everytime i download my music from my computer, my Sansa freezes up and cuts off.
  • Anonymous Mar 04, 2008
  • codyh Mar 04, 2008
    i load my music on it with my computer and it shows up n the computer but its not on the sansa
When i try to put on more songs on mine it automaticly deletes some others what should i do
Posted on Mar 15, 2008
How do i get music on to my sansa clip+?
Loading Music
You can transfer music from your computer to the Sansa® MP3 player using the drag-and-drop method or using music management software like Windows Media Player.
Drag and Drop (Windows)
Follow these steps to drag-and-drop music to your Sansa® Clip+ MP3 player:
Connect your Sansa® Clip+ player to your PC.
Select Open device to view files using Windows Explorer on initial connection or by going to My Computer.
Double-click on the Sansa Clip+ MP3 player.
Double-click on Internal Memory.
Double-click on the Music folder.
Drag and drop music files from your computer to the Sansa® MP3 player’s Music folder.
You can also drag and drop files to a microSD™ card inside your player by going to My Computer > Sansa Clip+ > External uSD Card.
Feb 07, 2010 | SanDisk Sansa Clip MP3 Player
I just put music on my card but i dont know how to load it onto my phone. can someone help?
First you need to make sure that the music files that you put on the card are compatible with your phone. You have to tell the phone where to look for the music files. Access the menu on your phone, and look for "memory." You have some limited memory on your phone itself, but you want to access the memory card. You can also set your phone to "save to" the memory card as well for videos, etc., this way you won't fill up your phones memory, and it is easy to transfer you files between your phone and other devices, computer, etc. My phone for example will play only the files on my phone by default, until I set it to play files from the memory card. You need to learn more about your particular phone, not so much the memory card itself. Please rate appropriately and leave a response. I hope this helps and good luck.
Oct 23, 2009 | PNY 2GB microSD Memory Card
Sansa e-series won't read data/video off flash
did you record it using the provided converter ? also try and see if you copy it to the player itself if that works if it does then its most likely your sd card
Sep 25, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 memory card transfer issue
Attention all. To temporarily fix this, make sure you're in MSC mode, plug the mp3 into a computer and then right-click on the memory-card icon (E,F,G,H or whatever drive it tells you it is) and left-click Properties. Then run a check/fix function on it, and that should sort it out so that you can at least PLAY the music, though I still need to sort out the files because it's double-listed loads of them. Oh well... hope that helps.
Sep 12, 2009 | SanDisk Sansa e260 MP3 Player
Problem getting video to expandable memory/sansa e250 to be recog
The Sansa will not play videos off the microSD card. It will play music, but not show videos or photos.
To get the videos onto the Sansa, use the Sansa Media Converter. If you don't have the SMC, you can download the Windows version from
Jan 06, 2009 | SanDisk Sansa e250 MP3 Player
Creative zen music will not play on memory card
I also use Napster. Unfortunately with the music being on the memory card and not on the device itself, Napster detects this and will not play music from the memory card.
There are two things you can do to resolve this, the first one won't cost you anything. Move non-Napster music files to the memory card, leaving only Napster music on the device itself. As a Napster-To-Go device, you'll be able to play and sync without issues. The second is to purchase the tracks from Napster that you want on the memory card. Once you do this, you can play them in any compatible media - not just the Zen device.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Sansa 250, and media converter won't recognize new mini sd card
The Sansa will only play videos stored in its internal memory, not on a microSD card. You can put music on the card, but not videos or photos.
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E260 Transfer Music with Yahoo Music Ulimited
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jun 13, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Music keeps "disappearing" from memory card
You have to go on and thay will let you
download music.
Dec 24, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sync to player and memory card without duplicates
I got this from: Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
