Question about Hitachi 43FDX01B TV
Dead set been throught the obvious but still won"t turn on
Hi all, I have been reading all the other post that involved this model being dead. I have a problem where the tv does the chirp and the power light stays on but I have no picture or sound. I have already replaced the STK ic's as well as all the respective resistors with no luck. I have gone as far as replacing other components, such as FBT, H.O.T, and other related components (FBT had signs of arcing. Did the maintence as I am working on the set) (This is my set) However I still have no luck getting the set to fire up. If i unplug connector (PQD2) I get sound, and voltage from the power supply on the Deflection board. Not all voltages are correct, and there is still no H.V. At this point DP37 is on but DP 29 is still off. I've checked everything. I have hit a brick wall!! Any help would really be appreciated. Thanks
  • Nhan_d93 Apr 15, 2008
    My TV set 43FDX01B has the same problem (chirping sound, no picture). I unplugged all CRT connection and still have the same problem.
    Please advise next step.
    Thanks,
    ND
  • JohnTVman May 11, 2010
    I am having the same issue..please advise me as to the next step
  • 149 Answers
Did you try disconnecting CRT sockets or picture tube anode ? if do so disconnect sound board I had same problem if still have the problem I may hel you e-mail me
Posted on Mar 29, 2008
Fuse for radio 1993 jeep Cherokee
anthony he ask for radio fuse.... fuel dont run radios.
the fuse is marked RAD.
did you check all boxes?
fuse boxes ?
the operators guide lists it.
the full book is here
read page 200 pdf
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
read that yet?
under RAD and wiring?
XJ jeep. 93 is first good year.
radio dead or just back lamps in it dead. why must i guess?????
ill pretend the RAD is dead. totally.
fuse 2 is RAD 15amps.
in the book, 1min to find. it.
4.0L engines???? guess that?
pdf page 200 and 142 (4LITER)
radios have 3 power feeds
illum
radio power
memory
ill guess, rad power is dead. runs Cig lighter too... it dead?
ITS MARKED .
Jul 04, 2014 | 1993 Jeep Grand Cherokee
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
The 'key in ignition' warning sound won't turn off and my battery went dead. How do I get it to turn off?
Pull the Battery Post off the Battery then the fuse If that don,t work Cut the Horn Wire To It
Mar 04, 2013 | 2004 Ford Windstar
Won't turn on
im sorry for posting the obvious, but is the battery perhaps dead?
Dec 28, 2012 | NOOK Tablet, 8GB
If I remove the battery on my mother board will I lose my settings??
The CMOS battery really doesn't hold too much. It mostly saves things like date and time, but since the advent of the internet, most of the CMOS settings are re-calibrated every time you connect to the internet(most of us are connected at all times now). Change it at will. You probably won't notice any change at all.
Nov 10, 2012 | HP Computers & Internet
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Hitachi 43FDX01B TV Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
