Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Clean water tank
First time using.
Clean water willnot dispense
    President:
  • 1,673 Answers
Will the water come out of the tank when you depress the valve at the bottom og the tank? The tank sits on a resevroir asm., is the seal on it, black and round. Inside the handle is a rod, so when you squeeze the trigger, it pushes onto the reservoir to release the water, check to be sure it is, if not then you have a problem inside the handle or a bad reservoir asm. is bad.
Posted on Feb 28, 2008
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Will spray water, but not solution
Hi there! The clean water tank has two spring loaded valves that releases the contents. Fill the clean water tank with water on both sides. Hold the cleaner up and push the valves in on both water and solution side. Both valves should push in and contents should drip out. If not, the clean water tank will need replacing. To order a replacement tank follow the link. Search Results The type of solution you are using can also prevent the solution from dispensing, be sure you are only using the recommended cleaning solution for this cleaner. If the clean water tank valves seem to be working fine, there may be an issue with the pump assembly that delivers the solution. We would recommend taking the cleaner in to an authorized repair center for service. To locate the nearest service center to you follow this link > Service Center Locator Hope this helps!
May 31, 2014 | Hoover F7452-900 All-Terrain SteamVac
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My Bissell ProHeat 2X CleanShot Upright Deep Cleaner, 9500; flow gauge will not spin and the machine is not dispensing solution with both the solution and water tank full. I have cleaned all inlets where...
No what it means are the tubes that carry the solutions are plugged and most likely full of old detergent that hardened. You will need to clean all the plastic tubing out for the dispensers. When your done using the machine always run clean water only through the dispenser and tube to flush out the detergents.
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Detergent bottle keeps falling off, wont stay put and clean water isn't emptying at all
The tank assembly needs to be replaced. Keep your tank handle. The other problem is your water not dispensing. There are electric solenoids and a pump that control dispensing soap and water. Take it to a repair shop for complete diagnosis before you replace the tank. The new tank is better, both soap and water tanks are in one assembly
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 04, 2009 | Hoover Vacuums
Cleaner willnot dispense water and vaccum it again. Soap dispense fine. would like a owners manual.
sounds like you have a clog in the waterline, or a pinched hose.
Locate the water line hose, disconnect, and blow through with can of compressed air.
If nothing goes through...you have a blockage/pinch.
Sep 18, 2009 | Bissell 1699 ProHeat Clear View Upright...
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
