Question about Akai PT5492S 54" Rear Projection Television
Question Only! Does anyone know if this unit has a digital receiver? Tyring to get ready for the "Big Switch" next year when it goes from analog to digital. Appreciate any and all help. Thanks
  • Jonathan Stewart
    Jonathan Stewart May 11, 2010
    As long as you are on cable or satellite you should be unaffected. The only people the HD transition is going to effect is people on standard antennas.
  • Jonathan Stewart
    Could you please be more specific on the make and model of your set? Thanks.
Well thank you for the info. I am on cable so I guess there will be no problem. Appreciate your time Jon865
Posted on Mar 16, 2008
How can I get free channels from my tv Philips mod 15mf605t/17
you need antenna for the tv
if the tv is digital than in needs digital type antenna version
if you have analog tv than piece of wire, metal coat hanger, analog antenna version
analog versions:
you can pick up cheap at swap meets, yard sales, goodwill, where every they sale tvs, radio shack,walmart, target, homedepot, online,amazon.com, ebay, friend. and so on.
digital versions:
where every they sale tv, radio shack, online, amizon.com.
some digital and analog unit comes with a built in amplify this is very nice to have if you live in a big city or out in the country help with receiving amplified signal to the antenna receiver unit.
Oct 06, 2015 | Philips Magnavox 15mf605t/17 Lcd Tv Screen...
I would like to know if this TV model is digital raedy.It has a MFG. date as 2000 I want to take it on a trip if it is digital ready. Thank you Thom
If the tv it is flat and tv LCD screen design than it is digital ready.It well be able to pickup free DTV air broadcasting from tv channels stations.If tv it have a big back and bulky design like it have CRT-tv tube.It well not pickup tv broadcasting in tv digital channels,all tv channels went digital on 2006.
Jun 30, 2011 | Televison & Video
Dont know what rca jack goes where or how to wire up unit.
if you could be more specific on the model of amplifier/reciever you have I might be able to help you. also tell me what your are tyring to plug into it.
Mar 14, 2011 | Audio Players & Recorders
Analog is cutting in and out while channel isn't being changed. Also, channels in analog have no sound at all. I tried to switch signal select to auto and the problem continues. what should I try next?
If you're only using analog audio, switch the signal selection to manual or analog.
If the source(s) that do this are primarily digital and they experience any problems the unit will want to dynamically switch to its analog path. If there's no analog path connected from the same device(s) you'll get silence every time it switches to analog. Observe the display when the problem occurs.
May 30, 2010 | Pioneer VSX-90TXV Receiver
Orion television cannot access digital services
I found the solution on AV Forums. Here's the link:
http://www.avforums.com/forums/lcd-televisions/635155-orion-tv-products-help-advice.html#post6566313
Jun 20, 2009 | Orion STV2763 27" TV
Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Apr 11, 2009 | Denon AVR-1403 Receiver
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Analog VCR
no you can use your regular VCR. You will just have to make sure you put your coverter box to bring the signal into your vcr. You can also bring the signal into your TV from the vcr so that you don't have to have 2 converter boxes.
Jan 23, 2009 | Memorex MT1134 13" TV
Dvd with analog tuner work when swithc to all digital signal next
This unit will only work if you have a digital cable connection box. If you get cable service you will have this service if not you will need to buy a digital to analog converter box. This can be purchased at any large electronics store, like Fry's or the Micro Center. You can also purchase them on line. Use you favorite search engine and plug in Television digital to analog converter boxes. The search engine will bring up places to purchase them. I hope this information help you with your problem.
Dec 02, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Akai PT5492S 54" Rear Projection Television Logo
19 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
