My unit was sitting in the garage at 15-20 degrees for a few weeks with a small amount of water in the tank and the valve at the bottom of the bladder was frozen to the base. When I pulled the water tank out the small black plunger, washer, rubber valve and spring all came out. They do not look damaged but I need to see a diagram to know the correct order of the parts to re-assemble. Can i press it all back in and have a good seal on the valve at the bottom of the bladder? Do I need to remove the small phillips screws reinstall the valve from inside the tank? If it wont seal, where can I buy a new valve assembly or bladder?
