Washing machine not spinning
I have just installed the machine after it sat in storage (dry and clean) for two years. Functions ok but will not spin. Could there be a drum lock applied by the movers? (not mentioned in the instructions). Other ideas?
Thanks - this was a bugger to get in to a confined space and would be even worse to remove.
  • 1 more comment
  • Elifandbill Feb 26, 2008
    Model Hoover 750 LA (australian made)
    Turns out there is a switch to have drip dry (i.e. no spin) - spin will work if we have this switch ON, and then manually advance to spin. Better than nothing....
    Thanks for comments aborcass
  • Ron Coons
    Ron Coons May 11, 2010
    manufacture and model if poss
  • Washing Mach... Master
  • 2,651 Answers
Not famillair with that one but jsut found a picture and looks as if it uses a lid lock, do you hear it clicking when door is open and closed. for safety reasons most machines wont run if it doesnt think lid is closed, id start there
Posted on Feb 26, 2008
LG WM2101H won't dry until many cycles
Won't dry? I guess you mean spin enough water out? Depending on age, warranty, It sounds like a worn or bad drive belt or possibly a problem with the discharge pump not working properly.
May 04, 2015 | LG Washing Machines
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email:
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
How to spin dry
Hi there
A short history Around fifty years ago the washing machine and the spin dryer were two separate machines. After that came the twin tub, where the two machines were put into one, then we got the washing machine-front loaded. As well as the dryer. Now we have got the dryer and the washing machine combined.
My guess is that you have to push a spin button and decide which speed you want the spin.
good luck
Apr 15, 2012 | Washing Machines
My Simpson Esprit 655 washing machine is not the spinning the clothes dry. Everything seems to be ok.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 07, 2011 | Washing Machines
My washing machine has started making a noise when it should spin, and doesn't drain on the spin. It Starts the cyle ok, and drains, but the problem is when it spins. It isn't spinning at speed - it is...
Either your pump or filter or outlet hose is blocked Clean out the filter/pump and make sure the outlet hose is not blocked.
Difficult to help without make/model??????????
Jan 27, 2011 | Washing Machines
Washer will not spin when it gets to spin cycle
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
May 16, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Banging during high speed spin cycle
Laco, drop the bottom front panel and see if all of the shocks are in tact on the tub assy. They just insert and lock by turning. If these are ok, check the back belt pulley. Sometimes one of the tines will split or crack and you will get this symptom. back.
Mar 04, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
