Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
No Video on Sharp Aquos LC-46D62U
Is their any kind of reset on this tv besides unplugging it? I have lost all video but still have audio. The Input screen and Menu screens also do not display. The screen is a glowing black/blue when on.
  • 1 more comment
  • wadford Feb 26, 2008
    I have checked all inputs all give the same result;No video just audio.Currently the tv is only connected to the Roof antenna via coax;only receiving audio.
    If I hit the menu button the menu does not appear on the screen. If I hit the input button the input menu also does not display on the screen.
  • Anonymous Mar 15, 2014
    All of a suddDuden I lost the sound on tv. Mute is not on, audio menu seems good
  • Anonymous Mar 22, 2014
    movies from flash drive play for approximately 23 minutes the video freezes but audio continues.
    Champion:
  • 208 Answers
Have you check all inputs as the HDMI inputs and the composit inputs are processed on a different bd?
Posted on Feb 26, 2008
  • Les Price Feb 26, 2008
    It sounds like you do not have the backlights, which means you either have a bad inverter or a bad panel. Shine a flashlight into the screen and hit the menu button, mover the light around and see if you can see the menu. This is repair that will require a qualifier Sharp tech to repair. I believe the inverter is most likely what has failed. If the unit is less than 1 year old Sharp will cover the repair.
My Sharp Aquos lc-46d62u has audio but not video. Only a blue screen
If you are using a box of some kind remove it and the set from power for a while and then plug back to allow both to come on and reboot---blue screen usually means no signal seen..........check the other inputs on set with a dvd player etc.
Nov 02, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
IPod player won't show on screen of my Sharp LCD LC-46D62U
Hello !
Guess the the cables are not proper connected or cables might have some problem ... or the ipod is not supporting to ur TV output ... first u try out with other Tv and confirm ...
Dec 10, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I've lost my TV remote. How do you manually turn 0n the power for the shar Aquos
The power button is on the top of the tv on the right along with the channel, volume and input button.
May 26, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I connect my Logitech music system to the TV. What connection and plugs is required? Kindly advise.
If your music system is only audio,then you need two RCA type audio cables pair for left& right audio channels(male pin jacks).Connect them at Music system audio output with left & right channels accordingly while on yr TV,connect the other ends to the audio Input jacks(female type). If there is a video out also from your music system then add the yellow video cable as well in the same way.
Aug 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
Blue light flashing along with a green intermitent flash
Very comon with sharp aquos,try unplug,replug tries the power button on off couple time.Tv should work,don't than ur video backlight main board it dead.
Nov 12, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos won't turn on
Any indicator lights on, if it is then you only have the standby 5v circuit working, you will need to have the power supply check out first, that is a starting point.
Oct 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
1,769 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
