Question about Kitchen Ranges
I HAVE A FRIGIDADAIRE DELUXE BUILT IN ELECTRIC STOVE, COOKMASTER PROBABLY 25 YRS OLD. THE CLOCK FOR SETTING THE TIMER HAS STOPPED WORKING, IS THIS PART AVAILABLE ANY WHERE? THE MODEL #RBE94N. THANKS ED.WINSLOW
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Clocks that old generally not available for purchase. with a little bit of searching you can probably find a company to rebuild it for you. you send to them they return it to you.
Posted on Feb 26, 2008
What buttons do I turn on my 25 yr old Kenmore stove to use the cleaning feature
I think that range had a mechanical clock. On it, you have to set the start and stop time (and push or pull the knob(s) to activate it), close the lock lever, and set the temperature and function dial(s) to self-clean. Unfortunately, if your clock isn't working (which is a common failure on stoves this old), you won't be able to run the self-clean cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 14, 2014 | Kenmore Kitchen Ranges
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a cookmaster 100 dual fuel the clock has gone out and the fan oven has stopped working the other oven and the grill stil work ok
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Jan 06, 2010 | Ovens
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
Oct 20, 2009 | Viking 27" Professional Select Built-in...
I have an old whilpool kitchen range and I moved and the timer buttons got turned. How to set the timer buttons to get the stove burners and oven to work, lost the manual.
if you have a clock where the hands go around and smaller start and stop clocks, here's what to do. set the clock to current time, push in the stop button and turn it until it stays in, then push in the start button and turn it until it pops out. try this.
Oct 15, 2009 | Whirlpool Ovens
Hi; We have a Whirlpool Gold range and stove - roughly two years old. The stove works but the oven and all functions ie clock set, timer do not work at all, not even a beep or anything appears on the creen...
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Aug 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Dishwasher won't cycle through to rinse/dry/stop
Your timer switch is most likely defective.
It probably needs to be replaced.
It is like a clock with switches at different times
If it is stuck at a particular time it will run there forever.
Before servicing disconnect power!!!!!!!!!!
You can remove inside door panel with about 6 phillips screws or so.
Timer is directly attached to the dial on your machine.
These cost about $100.00 or less.
Can also be found used online for cheaper.
Oct 26, 2008 | Kenmore 24 in. 17512 Built-in Dishwasher
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
