Did install but says computer does not have wired connection to router
  • 72 Answers
Can you give me more info on your problem or your trying to do, so that I can troubleshoot your problem.
Posted on Feb 26, 2008
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
Jul 19, 2013 | D-Link Computers & Internet
I have a 2 wire wireless router. Both computers
you should your lan to ruter cable install it again carefully.
Feb 20, 2010 | 2wire (1000-400108-001) Router
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
So how is the other computer supposed to work on the internet, if this wireless router is hooked up with the current modem? If I need another part, then why did I spend $150, and not get all I needed??
Before you bought the wireless router, you probably had one computer directly hooked up to the modem (the box you got from your internet provider). The wireless router should have come with a cable similar to the one that had previously connected the modem to your computer.
When you use a router, the original cable from the modem is disconnected from the back of your computer and is instead plugged into the INPUT of your router. The cable that came with the router is then plugged in to the original computer.
So far, so good.
Now, when you want to add additional computers to the internet, you can do it in two ways: either wirelessly (which means the other computers need to have wireless capability already built in - which is the case with laptop and notebook computers, or they have to have a wireless card installed); or you have to purchase another cable (like the one that came with your router) to directly connect the other computer to the router.
The only time an additional cost would be involved is if you needed to purchase another cable (for a direct connection), or if your other computer doesn't have wireless capability.
Does that answer your question?
Jul 07, 2009 | Linksys WRTP54G-NA Wireless G Broadband...
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
ROUTER INSTALLATION AND CONFIGURATION
connect existing modem to the router
reset router (located at the back)
connect computer to one of the 4 ports of the router
run internet connection wizard & choose "computer is connected to a gateway / internet connection is always ON"
for wireless:
connect a computer to the router hard-wired
for your router, open a browser and access 192.168.1.1
leave it blank for the username and admin for the password field
click wireless tab, change the Wireless Network Name (SSID):
click save settings
next click Security Mode: and choose WPA2 Personal
make a password in the WPA Shared Key: field
click save settings
on the computer, go to view available wireless network & click the wireless network name you made, connect, enter password when prompted.
good to go
Jan 24, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G not connected to internet.
YOU NEED TO CALL THE 800 # FOR LINKSYS AND THEY WILL CONFIGURE THE ROUTER WITH YOU FOR FREE OVER THE PHONE JUST HAVE PATIENCE THE TECHS ARE INDIAN.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
I can't get internet connection when the router is in place but it works without it, i no longer have my instalation guide or software(cd)
The only "installation" you need for the router is to connect it to the modem, plug in the power and, if it's a wired router, to connect it to the computer.
Then configure your computer's internet connection to connect to the router. (How you do that depends on which operating system the computer is running.)
If you're getting a wireless connection with no router, you're connecting to someone else's router - which is both illegal and dangerous (it gives them access to your computer).
Aug 20, 2008 | Computers & Internet
My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
did you have to install a connection program on one of your computers when you first installed the modem?
do you have an account name and password from your internet service provider, which is required to connect?
Mar 24, 2008 | NetGear WGR614 Router
Connecting router into a several computers
if u r going to connect ur pc through wired no need to install any thing>run a cable from pc to the ether net jack on the cisco router and it will start working>u need to use rj-45 cables>
if u r going to use pc's through wire less then u need to login to ur router and change the SSID name as ur wish and enable the ssid broadcast>and change the channel 1 or 11>and save that >and restart the wire less pc's>and in the pc right side down corner u can see wire less i-con>click that and click on view avaliable net works>and search for the SSID that u changed in the router screen and click on connect rate me solved if its help thx
Nov 11, 2007 | Cisco (WS-X3011) Router
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
