Question about Car Audio & Video
Wiring diagram needed
Need to know wiring diagram--what do the colors represent
  • Anonymous Apr 28, 2008
    I'm trying to find a wiring diagram for a pioneer deh p4000 supertuner lll, and a pioneer cdx-p670 changer.
  • skeenstom Sep 09, 2008
    is the brown wire supposed to replace the yellow wire on the Pioneer DEH - P4000
  • 199 Answers
Hi need to know the make and model :)
Posted on Feb 26, 2008
3 Suggested Answers
Eagleeyes
  • 199 Answers
SOURCE: wiring diagram needed
http://www.service.pioneer-eur.com/peeservice/RegistrInstrMan.nsf/search?openform
hi you can download your manual from here
Mark
Blue ICE
  • 18 Answers
The Pioneer website has both the OEM and Install Mauals in PDF format thast will solve your problems... I downloaded both earlier today...
Posted on Mar 20, 2010
Ignition wires red black blue and brown what do they represent
What make , model an year vehicle ? What ignition wires ? You mean power , ground , an control wires to ignition module or coil pack ! Would need to look at a wiring diagram to say for sure . Do you know what a wiring diagram is ? http://bbbind.com/free_tsb.html free wiring diagrams .
Jul 26, 2016 | Cars & Trucks
Where is the headlight switch relay
The wiring diagram below shows what you need to end up wiring to make this work, so if you know how to read a wiring diagram and feel like "skipping ahead", just go click on the thumbnail for the wiring diagram and check it out in full size, full color glory. It's shown for a four headlight system - if you have a two headlight system on your car, pretend the two inner "high beam only" headlights aren't there and you'll be fine. The wire colors shown here represent a typical GM vehicle (the green and tan wires, along with some of the black wires) as well as the proper/correct/desired wire colors to use on any new wiring you do (the red and some of the black wires). Also, this is shown as a typical "Bosch style" automotive relay with the connections numbered as such. If your relay is not numbered like this, then just identify the wires by function and go from there.
Note that in the original version of this diagram, I had the labels for the right side headlights reversed - it has since been corrected thanks to a sharp-eyed reader who pointed out the mistake to me. The wiring diagram was always correct, but the headlight labels may have been a tad confusing to some. Apologies for the mistake.
Jan 18, 2012 | Cars & Trucks
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
Wireing Harness Diagram 1982 Chevy S-10
Any auto parts store will carry these. Before you purchase make sure the volume you have has the electrical harness in it because some have the mechanical only. The store representative should be able to direct you to the proper volume you need. If you have to replace any wires in your harness make sure you do so with the same gauge & color wire so there won't be questions if later repairs are needed.
Oct 25, 2010 | Chevrolet S 10 Cars & Trucks
For a maytag dishwasher WU900 need a wiring diagram thanks Norm
Each component should be labelled clearly on your diagram. Look at figure 6-A. The symbols used to represent each component are pretty universal.
Wire colors are abbreviated and shown next to each wire. For example, Y means a yellow wire, V means Violet, R means red, LBU means light blue. Black is usually abbreviated BK, blue is usually BU. GR or GN are green, GY is gray. A wire color with a dash or a slash means --- with a --- stripe. For example BU-W means Blue with a white stripe, T/R means tan with a red stripe.
Figure 6-A: Typical Wiring Diagram
Oct 17, 2010 | Dishwashers
How do I replace the thermstor
first you need the diagram.... its located behind the timer// .control pannel ....get the diagram look at it ....look for thermister.in diagram .....look at the color code on diagram to find the part .....the wires are marked on diagram in color ...so if the diagram says thermister... wire.. in is blue //wire out.. is white.. look for
them color wires to find the thermister.... thats the only way i know ...let me know ..an good luck //joe// 25 years exp
Aug 31, 2010 | Kenmore Dryers
Need a wiring diagram or to know what colors are what
Click here to download the user's guide and go to page # 32 to see the wiring diagram.
Apr 23, 2009 | AudioControl KENWOOD KDC-MPV5025 Car...
Apr 01, 2009 | Pioneer CDX-FM677 6-Disc CD Changer
WIRING FOR PIONEER DEH 16 CAR STEREO
you need to find the Pioneer website, or something similer... google the DEH 1600 diagram. really you just need something that tells what the different wires represent by color. then find a wiring diagram for the make and model of your ride that cooresponds to your stereo set up... then just match up the wires and there you go... personally i suggest haveing one of the boys at Best buy throw a harness... it costs like 15 bucks or something. plus you know it will be done right, and you can take it back if its not and have it fixed... bottom line they will be liable for any problems... hope this helps.
Dec 30, 2007 | Pioneer DEH-1600 CD Player
Car Audio & Video Logo
917 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
