Question about Garmin iQue 3600 GPS Receiver
I can't seem to enable to voice prompts
The maps works great, they give me step by step but, can't hear the voice prompts. I checked the volume levels and they are all on high. Not sure what is going on but, would appreciate any information on how to resolve this issue.
Thanks
  • 2 more comments
  • Rod22 Feb 27, 2008
    Thanks so much for your advice. The voice prompts are working great!
  • minnie918 Jun 29, 2008
    I have a garmin 7760 nuvi and lost the voice promts.I hav edone nothing to try to correct this problem.
  • Anonymous Aug 13, 2008
    I had the same problem too with the voice, and followed his advise and now it works very well! Thanks a lot.'
    Jeff
  • airnut38 Aug 20, 2008
    My 3600 locked up so I had to do a quick reset, not the hard reset. However after that the voice prompts would not work. Not sure how to fix this problem.
Taken from the Garmin website:
"This error is most likely caused because the voice files need to be reloaded onto the iQue. Insert the iQue setup disk and select 'Install Software'. Then select 'Change voice'. Then select the voice to be installed on the device. When the voice files are finished installing, perform a Hotsync. The voice guidance files will then be restored to the unit and the voice prompts should work correctly."
Posted on Feb 26, 2008
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
Sound does not work on Garmin Street Pilot GPS
is sound enabled in the settings? I will get you instructions if you provide me with your model.
also you could try reseting the device, there is a reset hole or button. Model would help.
Thanks,
Ekse
Oct 23, 2008 | Garmin GPS
Nuvi2550 has no audible voice prompts
have you cked if it is muted? touch the speaker and when the volume control comes up you can see if it is muted
Dec 05, 2011 | Garmin GPS
Cannot get voice over to work
Check your audio options on the GPS. Sometimes the volume can be muted or the voice can be disabled through the audio settings. To do this, you will probably need to power on the device, look for an options screen, and then search for the "audio" or "volume" settings. Once you reach this screen, check if the volume is set to 0 or mute. If so, turn the volume up to a comfortable level. If the volume is already set up high, check the settings to see if "voice" is enabled or disabled. If disabled, then switch to enabled and you should be good to go. Let me know if you need anything else.
May 19, 2011 | GPS
Nuvi stopped talking. where is the mute button located on the unit?
If you are no longer getting the voice guidance from your gps, then you need to check if the volume is on the highest or lowest. There is no mute button on the gps, it is when the volume is at the lowest it seems muted. Ensure the volume is turned up by adjusting the scroll whell that is by the right hand side of the unit.
If that does not help, then you check the language settings in the unit. Verify that the voice is enabled, by following these steps:
  1. from the 'where to? view map' screen, touch 'tools',
  2. Touch 'language',
  3. Next to 'voice language' you will see 'jill' listed in the blue box on the right (if so the unit should be ready to use)
  4. If you do not see a 'voice' listed in the blue box, touch on the blue box,
  5. Select 'voice',
  6. Touch 'ok' at the bottom,
That should do the work for you.
Dec 23, 2010 | Garmin nuvi 205W GPS Receiver
Garmin 265 W won't speak street names
Below is the procedures for setting the languages...
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
or map data, such as street names.
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
Regards
Richard
Apr 26, 2009 | Garmin nuvi 205W GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 780
please click.
You should be good now
Regards
Richard.
Jan 23, 2009 | Garmin nuvi 780 GPS
This will work--go to Tools, Settings, Language and then select a Language that has TTS following it--this is the text to speech choice. Choose English TTS Jill if you like to hear the woman.
Mike H Dublin, oh
Dec 21, 2008 | Garmin nuvi 250W GPS Receiver
My Nuvi 360 volume for the voice prompts is too low, even on the highest setting. I also have a Nuvi 200, and the volume is fine on that unit. But if I get a phone call on my 360, the volume is OK. Is...
It is possible to turn up the voice level...but you have to be willing to hack the voice file a wee bit with a hex editor.
Just Open the .vpm file you want to modify in the hex editor, and search for "<voice_volume>96</voice_volume>" without the quotation marks...and change the numerical value - I have Australian Karen cranked up to 96. This makes the sound level of the voice prompts comparable to the MP3 level when I hook my Nuvi350 into my vehicle's sound system via the added line input that takes the place of the non-existent CD changer. Before I did this, when I played MP3s at a comfotable listening level, the voice prompts were too quiet. Now, they're comparable.
May 21, 2008 | GPS
Garmin iQue 3600 GPS Receiver Logo
229 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
