Question about Mitsubishi WD-52628 52" Projection HDTV
Color problems We've had our WD-52628 for about two years. Yesterday we noticed the color is all screwed up. We've done all the adjusting it said to do in the manual...but nothing helped. The best I can tell, there is no red!! Everything that is suppose to be red is either green or purple. Its horrible! We recently had to replace that bulb...but I wouldn't think that messed up the color.
  • cridley Feb 26, 2008
    Thank you Slinteriors - it did turn out to be a loose connection on our cable box! Who knew there were connections for all the colors?
    Its good to know that there is a color wheel, if that ever does need to be replaced.
  • Mitsubishi Master
  • 8,617 Answers
Your color wheel is bad. Thats the only thig that controls color on the DLP projections. You will need to replace it But I would check the connections on it first to make sure the connections are secure. Let me know if you require more assistance.
Posted on Feb 26, 2008
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Colors are off (NO YELLOW. BLUE) has a Green Hue to picture
there may be the possiblity of loose dvi cable between chasis and optical enngine. this is a cable much like a montor cable. it has two screws that tighten it down. reseting this sometime help
Dec 19, 2008 | Mitsubishi WD-52528 52" Television
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
52" DLP - TIled Picture
There is a simple tilt adjustment for this set if we could get a e-mail adress will send it to you
Feb 20, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Lost color sync
sounds like you have a convergence problem. replace the 2 convergence chips STK 390-110.
Feb 04, 2007 | Toshiba TP50G60 50" Rear Projection...
Mitsubishi WD-52628 52" Projection HDTV Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
