Question about Intel Motherboard
Large hard drive
Will this motherboard and bios support 48 bit so I can install a 250GB harddrive?
Motherboard Properties
Motherboard ID 03/25/2004-i845G-W627-6A69VM4YC-00
Motherboard Name Unknown
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
bios type phoenix award bios v6.00PG
system bios date 3/25/04
Lon
Posted on Jun 11, 2008
Version 1.07 is the latest BIOS for this MB
It has a 135 GB Limit.
I don't know a way arround that.
I am buying a SATA II PCI Controller...
Posted on May 08, 2008
    President:
  • 2,351 Answers
Yes it will. Mostly it is the operating system that will allow the drive to be see at its full size. Suggest you use Win XP home with at least SP1 but Win XP Pro with SP2 is faster & very stable. Also suggest you set the drive up with the Mfg's disk utilites. Bootable floppy or bootable CD. If using plain XP home you can still install the OS & than download a free trial of Partition magic which will allow you to combine any smaller partitions to get you up to you 250GB size. (only if you have a problem though.
Posted on Feb 26, 2008
Setting the second sata hard drive as main drive
In your BIOS there is a section on Boot Priority. Set it to where it always boots from your 1Tb hard drive and this will make it the master. Another thing I did before I installed mine was to take the side panel off (computer unplugged) and remove the little CMOS Battery. That causes it to loose volatile memory and gives you a fresh start.
It worked on mine, but don't do what I did, closely observe which way the battery is turned. You can put it in upside down!
Jun 07, 2012 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
I have just tried, for the first time, using my new 320GB Canvio. The white pilot light comes on, and I feel the disk spinning for a short time, but there is no operating software presented, and no file...
External harddrives do not come with an O/S. They are for external storage, beyond the master harddrive you have installed.
The master harddrive has the O/S.
The Platters are spinning because BIOS had a look to see what is on the Toshiba 320GB external harddrive.
[You press the Power On button. The first chipset to receive power is the BIOS chipset.
(Basic Input/Output System)
BIOS looks to see what devices are connected to the computer, does a Ram Memory count, turns the Processor on, then hands the computer over to the operating system.
BIOS finds THE harddrive with the O/S on it ]
http://en.wikipedia.org/wiki/BIOS
http://computer.howstuffworks.com/hard-disk.htm
When the Windows O/S (Operating System) is installed on a computer is assigns hash values to certain major hardware components in the computer.
A) Processor
B) Harddrive
C) Motherboard. (Motherboard chipsets and BIOS software on the BIOS chipset)
D) Graphics chip. (Whether it is Integrated Graphics, {OnBoard}, or a graphics card)
Change any two of these hardware components and Windows throws up a 'red flag'.
Microsoft's User License states, "One genuine copy of Windows per One computer"
If a hash value has changed, such as there are different hardware components, Windows 'feels' it is being stolen.
Why do you feel there should be an O/S already installed on the external harddrive?
Awaiting your reply please state in a Comment.
Regards,
joecoolvette
Jun 07, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
My HP 530laptop won't see any hard drive installed. No hard drive listed in bios . Can the bios be repaired if corrupted and id so can someone tell me the procedure? thanks in advance
If you want to try to repair the bios, in most case clearing the cmos would do it, and reset it to factory default. To do this, you are going to have to tear your laptop apart until you can get to the motherboard, there should be this nickel size battery installed somewhere on your motherboard. You will need to take this battery out for at least 15sec to let the cmos reset. Reinstall the battery, and put your laptop back togheeter, once powering up, it will prompt you to load default which you will have to set your system time agian. If you just want to load default value and not totally clear everything, you can go into your bios menu and on the exit tab, there is a load default value, and you can do this to set default value, but will not fully clear the bios. In your case of your laptop not seeing or reading your hard drive, ask yourself is it one harddrive or any multiple harddrive you had previous installed. If it is only one harddrive or the original harddrive, It could be dead, damaged, and that why the O.S cannot detect it and so with the BIOS menu too. Other then that, it could a bad hard drive expansion connection, since Hp laptop are known to heatup pretty hot.
Jan 17, 2011 | Computers & Internet
My hard drive is a wd2500jb and its only giving me 130 gb of space. How do i get the full 250 gb?
I assume the hard drive is installed inside the desktop computer.
Depending upon the age and make of the motherboard/BIOS, it may not support a hard drive as large as the 250Gb capacity. You maybe able to upgrade the BIOS version to allow it to access the full capacity of this hard drive. Go to the motherboard manufacturer's WEB site to download the latest BIOS firmware.
Sep 03, 2009 | Western Digital Caviar WD2500JB Special...
My Hard Drive is 250 GB but I only see 137GB
Windows xp has a max Hard drive limit of 137GB, so what you see is totally right.
Windows XP did not support 48-bit LBA for ATAPI disk drives, which is what larger drives needs.
The service packs do address the problem but you need to have a copy of windows xp which includes at least service pack 1 on the installation.
The problem is when you install from your original disk, it doesn't include the service packs, so by the time you have got the system up and running the hard disk space has already been allocated.
Bios update wont help
controller card won't help either
Possible solutions:
If you can get hold of a new version of XP which includes at least service pack 1, you can re-install with this disk and it should find all your hard disk space
or
You can do what is called 'slipstreaming', this is when you burn the original XP disk and the service packs together on one disk, but it does take a bit of working out.
here are a few links which may help you more:
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
http://support.microsoft.com/kb/303013
hope this al least sheds a little light on the problem
Bri
Feb 02, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
N600c's bios can't support 48-bit lba?
It depends what you want to use the laptop for but Windows XP SP2 (Disk needs Service Pack integrated), Windows Fundamentals for Legacy PC's and Windows Vista and Windows 7 will correctly address a hard drive within a machine that has the 137gb 48bit LBA problem.
Nov 01, 2008 | Compaq Evo N600c Notebook
Hard Drive Replacement on Notebook
your computer might not able to support this capacity i suggest calling the manufacturer for Hardware compatibility, if it does not recognize, then the bios might not be able to recognize this big capacity, updating to higher version of bios might help but sometimes not, it all depends on your motherboard config.
Sep 17, 2008 | BenQ Joybook 5100U Notebook
Sata harddrive
You need to enter the BIOS and check to see if the sata drives are enable cause if there aren't then you'll always get that response and seems as tho you waste your money.
Also you must have the sata drive on primary.
Get baC @ ME!
KJ
Apr 22, 2008 | ASUS P5LD2-VM Motherboard
Installing new hard drive.
From what it sounds like it is not your motherboard or harddrive. it is the formating of the hard drive. What is the format you are using for your harddrive ? FAT32 or NTFS ? are you Partitioning your drive ? Are you familure with dos commands ?
Sep 22, 2007 | DFI /LAN PARTY NFORCE4 ULTRA-D/...
Intel Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
