Question about Epson Stylus Color 740 InkJet Printer
Failure to print
My Epson 740 stylus has been working fine for the past seven years.Today I replaced both ink jet cartridges. When I turn on the printer, the carrier jams against something, stops its motion, all three red lights are on and the paper red light and green on/off light begin flashing. It will not print.
Myron
  • 3 more comments
  • vegaV Feb 27, 2008
    was assisted by fixya. Thank you
  • Anonymous Mar 18, 2008
    Have had my 740i for at least ten years.  I have noticed that even though the ink supply indicates there is ink, it does not print.  Changing the cartridges has solved the problem for the moment.  If I leave the printer unused for several weeks, the same thing occurs.  Yesterday I changed both cartridges, one copy came out and now nothing prints.   I have tried all of the cleaning tricks indicated and still no success.
    Any suggestions?
  • Kylesdad Mar 25, 2008
    My Epson 740 stylus has been working fine for the past ten years. When I turn on the printer, the carrier jams against something, stops its motion, all three red lights are on and the paper red light and green on/off light begin flashing. It will not print.
  • Ella Edgerton Dec 29, 2008
    Epson 740 Stylus Color 740 just seems to have quit printing. No lights to indicate empty cartridge.
  • Anonymous Mar 20, 2014
    Have replaced ink cartridges and the red light will not go off so I cannot print. Green light is on and not flashing.
Inyestores tapados extraerlos y sumergirlos en alcohol isoprilico varias veces ojala dearlos de un dia para otro yo entiendo el ingles pero tengo problemas para escribir no se como me enviaran lq forma de la lectura la pueda ver en español saludos desde chile
Posted on Mar 08, 2008
Epson Stylus C88 Ink Jet Printer only prints in blue but when i look at ink levels they all almost empty
Replace all ink cartridges and the printer will work again. The level indicators are just indicators and are not precise.
Jun 07, 2014 | Epson STYLUS C88 INK JET PRINTER...
My Epson stylus color 740 printer was showing replace inks so i did and colour ink is find but anything that is in black wont print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
My epson stylus 740 inkjet printer will not perform utilities or print.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 27, 2009 | Epson Stylus Color 740 InkJet Printer
Epson Stylus Photo R800 driver ran out of ink weeks ago. Today new ink cartridges arrived. Replaced all cartridges (even the ones that were ok) because the printer's low ink light would not go out until I...
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
Sep 22, 2009 | Epson Stylus Photo R800 InkJet Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Eson 740 will no longer print black ink
May I know if the printer is working on any computer.
It assume to be the Black Ink Head of the Printer is decayed. I mean to say the Surface where the Ink cartridge contacted to Printer, the film also need to be replaced. Plz check it to nearby service centre.
Apr 15, 2009 | Epson Stylus Color 740 InkJet Printer
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Jan 04, 2008 | Epson Stylus Color 740 InkJet Printer
Won't print black
just try with tet page of printer and also reinstall the driver and see. bye
Sep 26, 2007 | Epson Stylus Color 740 InkJet Printer
Printer reports always "out of ink"
The Stylus CX 4600 gets its jets clogged easily when you don't use it every day or so. Cycle through several times of cleaning the jets and printing the results, until it comes out right. I have had to do this as many as 6 times to get the test print to have no gaps, but eventually, it will always work if you clean them enough.
I have also had new cartridges report empty. I called the aftermarket source where I got them, and they had me return the cartidge for a free replacement. The replacement worked. Sometimes, paying 20% of the Epson cartridge price gets me junk cartridges.
Sep 23, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus Color 740 InkJet Printer Logo
216 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
