Question about Panasonic KX-FL511 Plain Paper Laser Fax
Kx-fl511 wont pick up paper
We have to put direct pressure to the paper and manually feed it in to send a fax or make copies and we have to feed each page separately. I ordered the feed assembly hoping this will fix the issue. Do you have any advise?
  • 2 more comments
  • kevinprofit Feb 26, 2008
    I will try that and let you know.
    worked, thank you for your suggestion.
  • momma_gx2 Oct 02, 2008
    when i i recieve a fax or when i sed one the paper goes only have way then it says paper jam check paper
  • perryhotz1 Nov 04, 2008
    it starts to feed, then stops. Sometimes it works, sometimes it doesn't. I put in a new drum, new toner, still doesn't work
    perryhotz@gmail.com
  • 47 Answers
Try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Posted on Feb 26, 2008
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Need owners manual for kx-fl511
go here for PDF copy of manual.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
Jan 18, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Trying to fax it reads sending 1 it will not pulled paper through
Try changing your separation pad . If your feed roller rotate clean them with alcohol.
good luck
Oct 07, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Need user manual
You can download a manual here:
Feb 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
FX-FL511 PLAIN PAPER FAX
Fax is not picking the paper from tray.just clean paper pick up ruler.or replace it.MIAN AKHLAQ
Jan 01, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
314 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
