Question about Acer (54.AA806.001) Sound Card
Microphone and external bose speakers stopped working
This happened at about the same time, is the sound card bad?
  • 75 Answers
It is not by sound card only ,check the sound utilities,driver ,and master volume control,
if all correct just remove the side panel (if u have PCI sound card or separate sound card) and remove the sound card and replug it,
if now not working u call to technition
regards
prasanna
pk86bhat@rediffmail.com
Posted on Mar 06, 2008
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
I hooked Up my stereo receiver tuner to a CD player and am using 2 bose speakers Sat in a dry storage for 10 years After first hooking up sound was fine next time I turned it on speakers reverbatate I...
Foam rot, all old speakers get it, you can get them re-paired or buy a do it your self kit for 30 bucks, its happened to a few times, easy to repair and bose speakers are worth it usually
Sep 08, 2013 | Car Audio & Video
The left speaker of my Bose On-Ear headphones suddenly stopped working although putting pressure on it makes sound come out for a very short time.
This may sound strange, but try slipping a piece of cotton on the area where the bare conductor runs through the plastic covering of the speaker (as suggested here). 39c682c9-7c92-4e14-963e-7b6eb35c074d.jpg
Apr 04, 2011 | Bose Audio Players & Recorders
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
Feedback sound like wind noise in right headphone of QC3, starts quietly and gradually gains in strength. Sometimes disappears, then comes back again. No sign of moisture in battery compartment. Any ideas?
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the lower half of the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When the foam has weakened or deteriorated to the point that the size and shape of the chamber cannot be maintained, more of the speaker sound is directed toward the microphone than the design can compensate for causing audio feedback to occur. This also happens when the lower half of the ear cushion is compressed. Since this is occuring during normal use,
it may be time to replace the ear cushions. They are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
Sep 18, 2009 | Bose QuietComfort 3 Acoustic Noise...
2 SET OF SPEAKERS WON'T WORK FOR ACER E380
Do these speakers came with the system? If yes then check your manual from the Acer's website ( www.acer.com)
Also what color ports do you have in the back of the Desktop?
I believe you have a green, a Blue and a pink port, the Green is for outgoing sound, the Blue is for incoming sound, like a tape player recorder or a External CD player to get sound to your PC, and the PIN is the Microphone.
Feb 11, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
My headphones are feedbacking all of a sudden
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It may be time to replace the ear cushions. If so, they are available from Bose for around $35/pair.
Mar 24, 2008 | Bose QuietComfort 3 Acoustic Noise...
Sound card broken? No normal sound and a constant buzz...
Sounds like you tried everything possible. Based on what you have stated that you tried already I would agree with your diagnosis of a bad sound card.
If this was my Laptop I would be looking for a nice set of USB speakers and Microphone or a headset.
You can either keep the speakers turned down or you may be able to disable the onboard sound through a BIOS setting.
Or even better. Here is a USB sound card with speaker and microphone jacks. Pretty Cheap too.
http://www.wolfcamera.com/product/EP4497467.htm
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
