I forgot my lock code..but i have the IMEI number if it helps..thanks
Sumone help me please :|
errr welll
my sister has given me her
old nokia n73 but she claims she
hasnt put a lock code in
AND the default does not work either
ive got my master reset code but
that wont work either :(
im stuck help man
I can't remove my old SIM card.. I really dissapointed.. I wish I never forgot my phone lock code.. how can I reset the code? I need it.. Please help me... >_<
358974017775440 this is the my n73 imei code but i forgot my password please help me
Reset your mobile through codes..get the code from your network provider.
. . .me toO HELP ME PLS this is the IMEI of my n73 358634016767836. . .this s my email [email protected]. . .
I have forgot my lock code of n73 my imei is 357651015409633
please give me any solution on [email protected] i will be thankful to you
Find your solution from the list,
Nokia N73
Codes:
Software & Hardware Problems
Find Solutions for other Nokia Phones:
Nokia N95
Nokia N70
Nokia 6300
Nokia 6600
All the other Nokia Phones.
This is my IMEI for N73: 353548021312633
Please unlock the lock code for me... Thanks
my email: [email protected]
My phone is locked (N73) and my IMEI is cleard From and i dnt have the package,
How can i do this
plzzz helpppp
my e-mail is [email protected]
reply plz
Hello i have a problem in my cellphone n73 i forgot the unlock code so i cant open it now how can i solve it now??please responce asap..tnx^^
Im here at the philippines
Phone Security Code: This locks the handset, as opposed to the sim card. Some phones will accept incoming calls with this lock enabled, but many require the code to be entered even to answer a call. You can also set some handsets to only accept a "new" sim if the phone security code is entered. The default code varies according the handset make and model. SIM Pin Code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. So which "lock code" do you need?.
If you need the Pin code to switch your phone on, after you enter the wrong code a few times, the phone will ask for a PUK code. This code is available from your service provider.
If you need the Security code, the Master code will work after you've entered the wrong code a few times, AND the phone request the Mater code, AND you leave your phone alone for approx. 15 minutes, before entering the Master code.
SOURCE: N73 unlock code
After changing the compony's default code'12345' to some other code which iforgot now i'm unable to reset the phone to its companys default original setting. pls help me to do so my Nokia model is N73 and IME number 359568018549991
SOURCE: Locked N73
Nokia MasterCode is:
4270752456
This code will reset any security code on your phone to one of your choice.
SOURCE: sir.. about n73 lock code
How to Unlock Your Nokia Cell Phone
Typically when you purchase a
cell phone, the company that sold you the phone 'locked' the phone
before you bought it, so you can only use it on their network. This
means that you can't use your phone on any other network, even if you
change the SIM (which is an abbreviation for Subscriber Identity
Module) card. The SIM card is the little piece of plastic that
identifies your phone to the cellular network. Changing your SIM card
to have your phone work on another network is useful especially if you
want to travel to another country and want to buy a pre-paid SIM card
so you can have cell phone access without roaming charges. There are
services that offer to provide unlocking capabilities for a fee, but
don't pay for them! You can do it yourself for free, which is the
perfect price.
Steps
1. Before trying
anything else, contact your service provider and ask for an unlock
code. Usually, if you've been a customer of theirs for some time, they
will provide you with an unlock code for free. This is, by far, the
best way to get your phone unlocked.
2. Download software to
generate the unlocking code. Software is available on some websites for
free and some pay websites that also offer support if things go wrong.
See external links below.
3. Find the Serial number of the cell
phone, also known as your IMEI number. This can be done by either
removing the back of your cell phone and looking underneath the
battery, or simply by typing in *#06# into your cell phone. It should
be something like: 030057361439976/05429508118
4. Using the
software you have downloaded, enter in your Manufacturer (which is in
this case Nokia), your model number, and your IMEI number. Also enter
your country and the Network. Calculate the code, this may be different
depending on which software you are using. If your phone is the Nokia
3390 phone, select the model 3310, they are the same phone.
* #pw+403927744443466+7#
5. Remove the SIM card from your Nokia phone. This is typically done
by removing the back cover of the phone and removing the battery and
sliding the card out. Put the battery back in and power the phone on.
6. You will see a message "Insert SIM Card". Enter all of the
characters you see in your code, including the # symbols. To get a 'p'
press * 3 times, to get a '+' press the * key 2 times, to get a 'w'
press the * key 4 times. Disregard any spaces in the code.
7. In
order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the
first code (MCC+MNC), use code "7" (Multilock)
8. Once you have
finished entering a code that works you should see a message that says
"SIM is not restricted" or "Restriction off" message depending on your
model. If not, try entering another code. Message "Cannot undo
restrictions" means the phone is "hard-locked" and cannot be unlocked
by code.
Tips
* Unlocking only
applies to GSM phones, phones using other cellular technologies, cannot
be unlocked without special software and hardware.
* Switch off
the phone. Hold the keys "3", "*" and "Call" and switch the phone on.
Keep the buttons held down till you see the word "Formatting..." on the
screen. Make sure that the battery is full charged before you attempt
this. This should reset the phone lock code.
Warnings
* Attempting to unlock your phone is done at your own risk. Although
unlocking your phone is legal, some cell phone operators might choose
to void your warranty should you unlock your phone (then again, some
cell phone operators won't mind).
* Most phones only allow you
to try a certain number of unlock tries, Nokia phones have a limit of 5
tries. After that, the phone becomes "hard-locked", meaning it cannot
be unlocked without using special equipment.
* Most of the newer phones will not work with the codes generated by the free unlock programs.
hi,thx for responded IMEI:355506013967499,and i have the master code 1707075516 but u can check it too,but still when i enter the master key it gives me u intered lock code incorrectly 5 times etc u know this message.still need help??thanks
i have same problem... i forget phone lock code.
hi i have got this nokia n73 phone. actullay i changed my lock code and it didnt work i dont no why, so i tuk it 2 phone shop 2 unlock it they charge me £10 and unlocked it 4 me and give me this new code which waz 12345, but what happend i changed it again and it dont work again, help me what shall i do? wheneva i put my code it says uncorrect
thanks emi
yes i forgot lock code , my mobile is not in lock mode , i can use it the mobile without any problem,i could not secure my mobile because it asking lock code , i forgot the lock code, now i am unable to lock my mobile . N73 ME.
plz help me ..... guys
i have tried the THC-NOKIA-UNLOCK.MDL
[email protected]
same as above
same also here ...i cant read my sms without the lock code
lock code of n 73
hii...i changed my lock code on my n-73 and i forgot it. plz help me
i have forgotten my code
i have forgotten my lockcode
hi there i forgot my lock code now i cant use the phone cos it was off my ime number is 355506013967499 and my email is [email protected]
i forget my password of my n73 imei no.359738005060977 please send me a solution for this waiting 4 your reply
email id ----- [email protected]
