Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
I have a VeiwSonic Monitor model VA712b that went blank.
The monitor power indicator light, lights up but turns orange after a few seconds and the screen flashes if I unplug it then plug it backup.Is there something I can do to get it back to working?
  • 1 more comment
  • hisquach85eg Mar 11, 2008
    This problem was fixed, I checked the power supply and seen 2 of the 4 capacitors leaking and all 4 swollen.Instead of replacing the caps I ordered another power supply cord, problem solved for now thanks!
  • Anonymous Mar 27, 2008
    i have a dell 19" lcd monitor that has an orange tint to all the time- any suggestions thanks
    kevinafriend@yahoo.com
  • hhall895 Jul 16, 2008
    When I start up the computer, I get the message, "No Signal - Analog" and the green power button turns orange and the screen goes black. Have disconnected and reconnected everything and rebooted the computer several times. Is it toast?
My monitor when I turn the computer on is black. The start button is green and then turns yellow. Could you let me know what is the matter with my monitor. I also get the message " no signal"
Posted on Jul 31, 2009
Sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Posted on Mar 10, 2008
Acer p223w monitor does not turn on
Try a different monitor, check the connections to the pc. When the monitor light changes to orange, press the spacebar to see if the light changes back to blue. Your pc power settings might need to be re-adjusted, is the pc going to sleep or hibernating too soon?
Jan 02, 2014 | Acer Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
LCD screen went blank
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 22, 2009 | ViewSonic VX2235wm LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Veiwsonic vx912 - ficking on/ off every few seconds
try different video cable or check it, if not power supply.
Apr 21, 2017 | ViewSonic VX912 19" LCD Monitor
Can't switch on monitor screen
Please try to connect the monitor to another PC, and it continues to happen when connected to another PC, then the hardware (internal electronic parts) is having trouble powering up the panel / ccds and it should be replaced / serviced according to the terms of the warranty. regards
May 12, 2009 | LG 22" FLATRON LCD Monitor
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Open Questions:
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
542 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
