Question about Whirlpool LER5636P Electric Dryer
Whirlpool Dryer Motor Removal
My Whirlpool Dryer has stopped tumbling. The heating element heats up but the drum will not rotate. I have the dryer on its front and am havng problems removing the blower fan to get to the motor. Any suggestions?
  • 2 more comments
  • Anonymous Mar 20, 2014
    belt ok heating element ok
  • Anonymous Mar 28, 2014
    Installing fan motor
    replacing fan motor on whirlpool fridge
  • Anonymous Mar 31, 2014
    Dryer not spinning but motor is running
    President:
  • Whirlpool Master
  • 2,651 Answers
Stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Posted on Feb 26, 2008
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
Element in the back seems to be heating but not spinning around. Cleaned filter.
the belt,motor,idler assemblage, drum glides and rollers are all parts the will effect the rotation of the drum. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Asko T712 Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
Whirlpool not blowing or tumbling
check to see if belt is still on drum. might have broke. thats the only thing that would cause the drum not to rotate but still should have air flow. the blower wheel is hooked up to the motor itself. your problem might be the motor itself has gone bad. if belt looks good then your motor is not turning.
Jun 22, 2009 | Whirlpool LER4634J Electric Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LER5636P Electric Dryer Logo
436 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
