Question about Dell Inspiron 710m Notebook
Power supply issues
My 710 recently stopped charging with the AC power cord. I have read about possible fixes. I would like to know if there is a docking station that can be used to charge the battery or at least power the laptop when in use.
  • cege Feb 26, 2008
    The power cord works I hve tested it on other lap tops. I'm pretty sure that it has to do with the laptop itself based on the research I have already done. I just want some info n possible docking stations that can quickly give power to the laptop.
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Have you checked the AC power pin (where the AC cord plugs in)?
Chances are that the pin has come loose from tugging and pulling on it. When this happens the battery charging is intermittent at best. The parts to fix this problem are usually under $10 but the labor if you take it in is gonna run $100-$200. You can repair it yourself if you're comfortable working with electronic components. Not that tough. WHen you get it fixed, invest in a Cable Retention device to keep it from happening again.
Here's a short video that talks about it. . .
Posted on Jun 10, 2008
  • 100 Answers
Better to u take from nearest service center and change the AC power cord.
Posted on Feb 26, 2008
How do I check internal power issues after I know my ac adapter and power jack are not the issue. My laptop will not start up and the led will not light up. Verified with multimeter up to motherboar
I would try removing the battery and power cord. You need to hold the power button down for 30 seconds. You can then attach the battery and power cord and see if it will power up. This may not be possible if the battery is permanently attached. You will be able to tell right away if this worked.
You may have a loose connection between the motherboard and the charging port. This would involve removing the motherboard and soldering in a new charging port. If this is what is wrong, it takes a professional to fix this issue. This is a rather involved problem to fix.
Oct 04, 2015 | Computers & Internet
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
I goofed. I have a Toshiba Satellite A105-S206, and I will make this as brief as I can. I have had a string of super cheap power supplies that I have been using. The most recent one stopped...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 06, 2011 | Toshiba Computers & Internet
The Ac power supply on the motherboard gets hot and stops allowing the AC power to generate power and switches to battery and eats the battery power really fast. then won't charge until PC is completely...
So the DC jack on the motherboard is Heating Up? I'm assuming the AC Adapter (charger cord) is also HOT...??
Here's what your issue is:
1. You're using the wrong volt/amp Adapter..(charger) For Example.. Your Laptop needs a 19.5v Adapter and you are using an 18.5v
2. You're using a "generic" AC Adapter and Not an OEM one.. the generic adapters will overheat and sometimes even melt due to Cheap capacitors/resistors being used..
3. You need to clean your Fan/Heatsink.. Clean the heatsink cooling fins to free blockage and stop overheating issue..
Or .... 4. Possible faulty battery
Nov 16, 2009 | Toshiba Satellite A75-S211 Notebook
Power source connection to my HP Pavilion dv 8000 disconnects often and connector must be reinsertd and jiggled to establish ac power supply
YOU SHOULD CHANGE THE CONNECTOR BEFORE IT BLOWS UP THE POWER IC'S THAT LINK TO THE CONNECTOR
IT'S A BIT LOOSE
Sep 12, 2009 | Computers & Internet
Power button
hello
Follow the instructions.
  1. Take out the battery and the Ac power. Keep the power button pressed till all residue power is radiated.
  2. now connect the Ac power without the battery and try to start the system. Hope you have fixed the supply with proper soldering.
  3. if the system gets start then there is no problem with your system hardware is OK.
  4. now try battery. charge it fully and this will tell you if your battery is good.
  5. if it works with power supply but not with battery then there are two possibilities.
  • battery gone
  • charging module in the mother boad malfunctioning.
Thank you
Aug 16, 2009 | Computers & Internet
Playstation not receiving power
This could be a problem with your AC power cord, try these fixes. If they do not work you ca contact sony at:
www.us.playstation.com/Support/PS3
or
www.uk.playstation.com/help-support/ps3
  • The console might not be turned on. Turn on the console using the main power switch on the back of the console.
  • Make sure the AC power cord is securely connected.
  • Visually inspect the AC power cord for damage. Do not use if frayed, cut, or damaged in any way.
  • Confirm the wall power outlet is active (receiving power). Try a different power outlet.
  • If possible, test the power cord by connecting it to a different PLAYSTATION 3.
  • If possible, try another AC power cord on your PLAYSTATION 3.
  • If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PLAYSTATION 3 power supply and the PLAYSTATION 3 may need service.
  • Make sure the vents are not obstructed in anyway.
  • Make sure there is adequate ventilation for the PLAYSTATION 3. There should be at least four (4) inches of clearance between the air vents on the system and any walls, televisions, entertainment centers, etc. Otherwise the unit may not function properly due to what are actually environmental issues.
  • Jun 23, 2009 | Sony Playstation 3 (PS3) Console
    Dell laptop power adapter problem
    What finish the story, if you wnat some help.
    Aug 14, 2008 | Computers & Internet
    Hi!
    It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
    Hope you find it helpful.
    Thanks,
    Karlox™ :)
    Jul 28, 2008 | Dell Inspiron 1501 Notebook
    Dell Inspiron 710m Notebook Logo
    125 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
