Question about Brother MFC 210C All-In-One InkJet Printer
Machine Error AF
Hi ! I have a problem wiht my mfc-210c. Initiation not completed. When i put set-menu, black print and 4 up, i got Machine error AF. The flat cable is good. Can you help me ? (sorry for my english, i'm for Québec canada)
Thanks !
Sylvain
  • Sean186 Feb 26, 2008
    I have test each pin of the flat cable, and each pin is good, (1 OHM). I have wash the flat cable with cleaning solution and the contact on the board. Can you tel me if the error AF can be show for another problem ?
  • kronk79 Apr 05, 2008
    hello i have problem witch brother dcp 135c it shows error scan AF and when start up hears strange plastic noises like rumble please help me
  • 832 Answers
Plz check the flat cables silver ends! It might be that the flat cable has a broken cable. Clean contact on main board and flatcable side with some electrical cleaning solution.
But i guess you have a broken cable.
AF only appears when scanner is not connected to machines circuit board. In case you wont find a broken cable, buy a second hand dcp 110c and use this scanner as a spare-part.
Posted on Feb 26, 2008
  • Mix-it-up
    Mix-it-up Feb 26, 2008
    Sorry. Just two cases: 1# Flatcable disconnected (99%) or main board defctive (1%).
    You can try another scanner top from a dcp 110c. If that doesnt work too the main board is defective.
Machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
thanks.
Jul 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C All-In-One InkJet Printer ERROR 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart you printer.
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean on mfc215c
PAPER JAMED IN MACHINE PROBALLY ON THE OTHER SIDE OF THE PRINTHEAD SO MOVE THE PRINT HEAD ACROSS AND LOOK IN THERE FOR A PIECE OF PAPER PROBALLY SOAKED IN INK, HAVE A GOOD LOOK WERE THE PURGE UNIT IS MAKE SURE NO PAPER THER .
Or
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error, not worth a cracker, replace machine.
press stop to exit if needed
Thanks.
Dec 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
1.unable to clean?mfc215c
press stop to exit if needed.....
OR
Thanks.
Brother MFC-210C keeps displaying unable to clean messasge
Hi I found this on your website for this problem, from Poster "Trickydicky": Rank: Apprentice
Rating: 96%, 81 votes
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C): I havent tried it yet but there were many recommendations from users who did and they recommend this solution- Good Luck the service centers said it would be $70.00 just to check it before any work is done. But if it's just a matter of pressing series of buttons to reset the cleaning counter, it's worth trying. REE
Was this solution helpful? Show your Appreciation by rating it:
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Not printing
Nov 21, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc machine error AF
You have to fix the scanner flatcable on the pcb. Its disconnected :-)
Sep 25, 2007 | Brother MFC-210C All-In-One Printer
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
404 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
