Sounds like you have the wrong firmware on the R4 card. I had a similar problem when I swapped cards with my granddaughter. I had the "R4 Revolution....etc" card and she had a "R4 Upgrade Revolution....etc". They look the same but un beknown to me they need different firmware!!
This problem is most likely caused by corrupt data on your SD card. Your best bet is to format the SD card and and reload the backed up data if you have any.
I hope the info listed above has helped in some way. If possible please rate this solution.
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
It sounds like you need to figure out exactly what kind of DS card you have. Check out NintendoDSCard.com's DS Card Setup Guide which should sort you out.
Also, I recommend only buying genuine cards since a lot of the fakes tend to break quite easily. Maybe from dscardworld.com or from nds-gear.com if you're in Canada/Europe since their international shipping's a bit cheaper
just delete games and reload those cards do that all the time, make sure you drag the games into the themes folder.open system folder you will find the themes /games folder in there.enjoy
to format the card is pretty simple really, all you have to do is:-
make sure your card is plugged in with the p.c same as you drag and drop go to my computer look for where your flash drive is dont click into it, right click it a little list will show go to format then click start (dont use quick format)
