? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
Jan 30, 2012 - 52 posts - 33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4.
2010 dragon 155 RMK electrical problems
Feb 3, 2013 Polaris update
100+ posts
Nov 15, 2009 ~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009 M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008 More results from www.snowest.com
Cud be the ignition module or ur battery is old. Must hold 12.6 volts at all times no less . Alternator or the bikes wiring may be bad. Chec for. Burnt fuses too. Buy a troublshoot book like haynes
hi, i have a 1987 polaris trail boss 4x4 was riding and gas was leaking from the under side front of gas tank, is there a hose from the carb there? Anyway when i noticed the gas leak we stopped and it slowly ideled down until it died and then would not start.
I have spark pulled carb and cleaned i get gas.
can you help?
have you ever had polaris(s) before! my magnum does the same thing , it is a safety thing press the yellow button on handle bar while on reverse and you will go as fast backwards as forward
everything works but no spark WHat can i do too see whats wrong with it ? It Just Died out on me when i was drivein :( a polaris trail boss 330 2004< NO Goood i guesss
