Nintendo DS Lite Console Logo
Posted on Feb 15, 2010
Ds lite turns itself off
When i switch on my ds lite the screens flash and then it turns itself off again charging ok did get it to come on for 2 mins which both screens were working but then switches back off again
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 15, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
251
Points
7
Call the number on the back of your game for help and they will help you if your warranty wil cover it
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
When I turn on my DS lite, the green light and bottom screen flash briefly and it turns itself off. This is even with the charger plugged in (which indicates that it is charging).
Hi there, this is unfortunately because the top screen has become faulty. Whichever screen flashes it is the opposite screen that is faulty.
You can buy the screens quite cheaply from such places as amazon and ebay.
To replace the screen itself is a little tricky, especially as it is the top screen that is faulty.
If you do an internet search on how to replace the top screen of a ds lite you will find that there are plenty of guides out there but please read through them first to make sure that you are comfortable carrying out the repair.
Hope this helps and thank you for using FixYa
My ds lite wont turn on. When I switch it on, The screens flash and it turns off again! It still charges, What ddo I do. I dont want to buy a new one!
Try removing the battery and putting it back in. Let it charge fully until the charge indicator goes away and then try again. If you are still having issues, it sounds like the device has become corrupted.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathon_2815d94e62f0ea08
Ds lite screen flash white tehm off
The screen that does NOT flash will need replacing.
It may look fine and dandy but there is still an issue.
The reason for the flash is that when switched on the DS lite performs a qucik check of the screens, if there is an issue the unit will switch itself off again.
My answer is, judging that you have said you have taken it apart to have a look that you are willing to repair it yourself.
Have a look on ebay for the relevant screen (plenty of people on ebay stock them) and then replace the screen that does NOT flash.
This should solve your issue.
If you need a guide to replace the respective screen click on my name to access my profile and at the bottom of the page you will find my guides.
Hope this helps,
Regards,
SOD69
2helpful
3answers
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Dropped Nintendo DS Lite on wooden floor - NOW IT WON'T TURN ON
remove the battery for a few mins and put it back in and try again?
Its a long shot but theres very little you can do with this, the insides of the DS lite are REALLY small and the only replaceable parts are the screen, buttons, etc. and you cant really fix damage to the board or chips inside which presumably is whats happened here if you get zero response.
Sorry.. :(
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
Nintendo DS Lite won't tur on
same with me but , i got a new one, and if i didnt i had to wait like 4 2 mouthes 4 nintendo to fix it. go to nintendo.com, google it, or get a new one
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
