Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytage 500 smooth top
Hi again,
I'll look for the two screws in the cavity. This is an enclosed element that appears to be accessed through the back or bottom under the pan drawer. I just can't seem to see how.
Ron
  • tamron Feb 26, 2008
    Thankyou tech 17,
    I was trying to find the way into the enclosed baking element.
    There was indeed two screws on the lower back side of the oven cavity. Got it!
    Thanks again,
    Ron
  • robert samples May 11, 2010
    whats your complete model num off your range and what are you trying to do
    President:
  • 1,314 Answers
Your welcome lol
Posted on Feb 26, 2008
Maytag medc215ew1 disassembly
Yes. Remove filter and you will see 2 phillips head screws. Remove screws and pull top toward you slightly while lifting. Top will tilt back and then 2 screws at top corners inside left and right side holding front on. The front can now be removed and this gives you access to the components you need to check.
Nov 28, 2016 | Maytag Dryers
How do you open the smooth top, on a Maytag range?
There will be 2 or 3 screws under the front edge of the top. Take them out and top will hinge up similar to the older models.
Unplugg the range before touching any wires. There is voltage on the thermal limiter on the element even when the switch is off.
Once you have access to the element you can check for power and continuity just like on an older range.
Post back with any questions. I will see if I have a manual on pdf.
Thanks/Mike
Nov 04, 2007 | Kitchen Ranges
Access ing the heating element
Unplug the machine and take it outside. Inspect the venti for lint buildup. Using a putty knife release the top spring clips then remove the screws that hold the front panel on. You cannot and do not work from the back side of the machine. Like this:
Aug 22, 2012 | Maytag MDE308DAYW Electric Dryer
Why is it not drying?
If your dryer is getting warm and just taking a real long time to dry then more than likely you a have a restriction in the exhaust line causing drying times to exceed the 3 hour mark. If your not getting any heat at all then read the next walk though.
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
May 29, 2012 | Whirlpool Dryers
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
I want to switch out the heating element...model 96281100....but I can't access the element because it is enclosed in a metal tube. How do I switch these elements?
Raise the top and remove the clip holding the top of the element chamber. Then lift out the heater chamber and remove the screw.themobilian_2737.jpgthemobilian_2738.jpg
More Here
Aug 03, 2011 | Kenmore Dryers
How do I remove the top on a Maytag range
Unplug the range from power.
Open the oven door. Look on the right and left sides of the oven frame just below the top. Remove the 2 screws. Pull the top forward. Remove the wiring harness connector at the back.Lift the top up and off. Set the top aside.
Nov 11, 2009 | Maytag MER5775Q Electric Kitchen Range
The bottom heating element has burned out....how
first unplug unit,then there should be two screws inside oven cavity where element leads exit rear of cavity to termination wire,take out screws pull element gentally toward you unscrew terminals &reverse procedure,some units may dis-assemble from rear so you may ned to access terms from rear w/cover on back removed
Aug 03, 2009 | Tappan Kitchen Ranges
Maytag 500 electric smoothtop
lower elemnet in lower or upper oven??, should be an expused elemnt 2 screws on back wall of cavity should remove it forreplacemnt.TURN OFF POWER FIRST it is LIVE!!!!!!!!!!!
Feb 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
Sep 23, 2007 | Frigidaire FEF365AS Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
61 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
