Question about Miele Novotronic Premier 500 Front Load Washer
What do you do if the Miele washing machine's check drain and inlet light is on?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Posted on Mar 29, 2010
4 Suggested Answers
SOURCE:
  • 183 Answers
SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Miele washing machine check inlet and check pump
PUMP NEEDS TO BE REMOVED AND DISMANTLED. CHECK FOR PAPER CLIP OR METAL PIN/ SMALL COIN AS THAT CAN CAUSE AN EARTH LEAKAGE WARNING WHICH WOULD GIVE YOU YOUR PROBLEM.
Dec 09, 2013 | Washing Machines
Miele washing machine w 487 check drain and check inlet
Clean out the pump trap. If you are on well water or just have very hard water, your inlet valve may be becoming constricted as well, remove the fill hoses from the back of the machine and shine a bright light into the valve to see if the screens are getting clogged with debris: In this case, follow the instructions the computer is giving you.
Apr 12, 2013 | Miele W487 Front Load Washer
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Jul 28, 2007 | Miele W2240 Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
1,061 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
