Hello!
Maybe you need to install the correct driver of your video card. But first update your motherboard driver, if you have CD/DVD utilities enlclosed in your computer from the vendor then you should reinstall that in series installation. after that installation restart the system and then install the updated driver or the current CD/DVD utilities of your geforce 8600 GT and again restart the system after installation. and then set the monitor display to the required display of your games.
May this help, best regards, melnavz
Trying to run too many programs at the same time can cause display
problems such as jittery or choppy video. If you notice erratic or reduced
visual performance on your computer, try one or more of the actions described
below.
1.The more programs you have open, the more system resources Windows needs. Try closing programs that you're not
currently using, or reducing the window size.
2.Even if you have only a few programs running, some programs (such
as video-editing programs) and features (such as high-definition television) use
a lot of system resources. Running too many of these programs at the same time
puts a strain on system resources and might degrade display quality or make
video appear jittery or disconnected.
On some computers, very high resolution
require a lot of system resources to display properly. If you notice problems at
high resolutions, try lowering the resolution until the problems disappear.
1 open display from control panel
In the left pane, click Adjust
resolution.
In the Resolution list, click the resolution
you want, and then click Apply.
If you set the DPI higher than 96, and you're running the Aero desktop
experience, the text and other items on the screen might appear blurry in some
programs that aren't designed for high-DPI display. To avoid this problem,
follow these steps:
To make text and on-screen items clearer in programs
that aren't designed for high DPIIf you set the,
follow these steps
In the left pane, click Set custom text size
(DPI). If you are
prompted for an administrator password or confirmation, type the password or
provide confirmation.
In the Custom DPI Setting dialog box, select
the Use Windows XP style DPI
scaling check box, and then click OK.
Im am currently unable to find my CDs. Any other help if i cant find them?
Ok. found my CDs and did exactly what you said. Problem still persists
